Fordmaster101 Posted March 12 Report Share Posted March 12 You 2002 yamaha banshee fresh rebuild wisco 65mm piston kit,hooned cylinder to 65mm .with t5 pipes with the t5 jet and needle kit. main jet 280 pilot 25 needle 4th notch sea level.float at 21mm.won't run out of both pipes. Tested coil ,plugs ,cross over tube ,reeds, no blow by from vent tube. Still has tors system .When you start it .it will run with the left pipe smoking /heating up right side nothing. While running a watery oil like substance comes out of the left pipe where it connects to the rear pipe. I've redone this thing 5 times still can't figure it out help. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 12 Report Share Posted March 12 Swap plugs, wires... side to side ( 1ata time) make sure air filter(s) aren't over oiled choke tube back on, slides in right direction... It still wont run at hi idle ~ above pilot? Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 12 Author Report Share Posted March 12 Have done that does not seem to make a difference. Slides in the right way dialed in together. No filters at the moment till i get it tuned .Will Rev up both still only out of the one side. And when you let off throttle it stalls out in a heart beat. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 12 Report Share Posted March 12 Squirt fuel in dead side, see if it wakes up, rats nest in pipe Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 12 Author Report Share Posted March 12 I sprayed a little starting fluid in dead side started little more easy but still was smoking out the left pipe. When I did rebuild took off pipes and polished them didn't see any kind of nest / blockage. The plugs look OK the right is fine little dirty after few kicks . The left plug gets more oil/fuel on it. But that's also the side that gets the drips coming out the the pipe to rear pipe connector. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 12 Report Share Posted March 12 Sounds like a fuel issue if it starts better with ether. Stand it up on end and see if the pipes full of fuel . If you swaped all the electrical side to side it's not that. you said you honed the cylinders. are they within spec to the piston? Oem or knock off cylinders? Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 12 Author Report Share Posted March 12 When I pick up bike liquid out of left pipe . Oem cylinder and in spec just can't figure out where the liquid Is coming from in the pipe Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 12 Report Share Posted March 12 (edited) 2 problems correct? Rt dead&The left one's, the one firing right? You might have to pull your pipe and drain it. If you do make sure pistons correct? Try draining the carbs ( make note of amount side to side), leave fuel off & just turn it on for a few seconds , to put some fuel in bowls & try that for the left. If you can keep it running, i'd try & squirt fuel in rt/dead side. Pickup clearance is good? Edited March 12 by 375hp banshees Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 12 Author Report Share Posted March 12 (edited) I'll pull the pipes off again. How do I make sure piston is correct? The arrow is pointing toward the exhaust port and moving up and down with out dragging. I'll make note of how much gas comes out each carb . Last time I ran some compressed air through the line to clear it of fuel and I noticed the right side had more fuel come out than the left .do you know what the tors screw is spose to be set to its all the way down on mine causing the slides to be almost sitting on the bottom of the carbs .and I'm not to sure what you mean by pick up clearance. I appreciate all the help Edited March 12 by Fordmaster101 Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 13 Author Report Share Posted March 13 Pulled the pipes left side has about 60ml of fluid in the pipe right side has none. With pipes off looked at the piston and kicked it a few times . No fluid was coming out while kicking both pistons looked good Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 13 Report Share Posted March 13 Pick up trigger ,to o.d. of flywheel gap. Dont recall on TORS. ( you can fine tune that later) just turn knob to raise them. it can idle high just to get it running, then adj. From there. Doubt that has anything to do with problem if, i assume, you were throttling it to try & keep it running? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 13 Report Share Posted March 13 Turning the TORS screw in (clockwise) raises the slide. There is no set starting point. I use the chuck end of a drill bit as a feeler gauge to get the 2 slides equal, then turn both idle screws the same from there. Fluid in the pipes will cause it to not run properly, I don't know how much or how little though. When I've flooded mine it was a considerable amount. Rent a cooling system pressure tester from a O'reilly's or similar parts store to test the cooling system for internal leaks. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 13 Report Share Posted March 13 @hoppedupandcutdown that new jalopy of your got TORS... pic's? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 13 Report Share Posted March 13 7 hours ago, 375hp banshees said: @hoppedupandcutdown that new jalopy of your got TORS... pic's? No, but the one in my profile did until just last year. I'll get some pics up soon of the new one. Quote Link to comment Share on other sites More sharing options...
Fordmaster101 Posted March 14 Author Report Share Posted March 14 Found my issue I believe pulled the flywheel cover and was full of rust water . Any tips on cleaning it ? Brake clean might be to aggressive so want some input thanks ! Quote Link to comment Share on other sites More sharing options...
