5 minutes ago, 375hp banshees said:
Can you swap the joints top to bottom?
 Are they different lengths?
top n bottom joints are completely different. cant swap
So your maxed out also? I guess maxed out is good enough.
caleb you look like you have 4-5 degrees now, what about when you sit on it? If it’s 3-5 degrees run it
according to my digital protractor, the camber is 1.50 unloaded and about .45 .50 with rider weight
Mine has room to go but it appears I have more camber than he does. I dont remember the exact #s, would have to measure again. Out upper ball joints seem to be close to the same location assuming they are the same. I have about 4-5 threads exposed past the lock nut.
noticed how my lower mounting point is welded crooked compared to dano3's. that right there can make a huge differencefe4cd243c463885830668191b5a58978.jpgd787ec4370e1dd9c77bfdfb56760d0bb.jpg
Sent from my SM-G920V using Tapatalk
  • Like 1
2 hours ago, 375hp banshees said:
Pull the bottom out some & you'll be perfect
ya cant with these arms. staying as it is, done dickin with it.. china joe ftw
  • Like 1
