trying to get my camber set up and having issues.  with proper sag and almost a level frame, i am out of adjustment on top ball joints. only have about neg .30 degree of camber. the only way i can get neg 1 degree or more is when i have the front end fully extended.. whats going on here
39 minutes ago, 375hp banshees said:
How do you replace them?
Sent from my SM-A505U using Tapatalk
they just bolt in, there is a "fork" in lower arm they slide into. then you just tighten them
lifted front end and set to 1.5 neg camber. said to hell with it, what ya get for buying cheap. they sit about .30 neg at rider level, oh well. my bigger issue is my steering stem. alba aswell, was welded crooked when i got it. so i cut it apart n rewelded. still didnt get it perfect, had to shorten 1 tie rod and i have one side turning more than the other at full lock. going to have to readjust and have bars a little off when strait
Sent from my SM-G920V using Tapatalk
lower ball joint goes into the fork, with just a bolt that threads in.. upper has the nut on either side
What keeps the bottom tight
It bottom out on joint flat spot?
Can you put a 1/2 nut between arm & joint to space it out a little?
I mean it can't un-thread but i wouldn't leave it loose
i gotta take a pic to show you how the bottom mounts. cant use a half washer. id have to take lower ball joint to work and have a spacer cut on a laser if i wanted to go that route
tride getting the best pics that i could. broke my main camera now gotta use the selfie one to take pics 2c31dfffdf5b1a43c47a189923842df4.jpgb30e31c4a476887136582c7c12e57471.jpg2c9792eeec49a08f8e0152bcb2eff9d1.jpg31341ee135e2192bc2e6b3038fc7b311.jpg
