caleb90 Posted March 6, 2021 Report Posted March 6, 2021 alright, i am anal as hell and try to make every thing perfect. i wasnt happy with the alba brake line kit that came with my a arms, to much extra line. ordered up a double line streamline +2 kit as i have +2 arms +2 steering stem. got the kit and its worse as far as extra line length. clears the bars by a good 8in after being run and looks like shit all looped in and flopping around behind the radiator. there has got to be a better way as far as running these lines. imput much apreciated Quote
Keno Posted March 6, 2021 Report Posted March 6, 2021 Measure out what you want and contact Apex. They are one of the sponsors here. Quote
ATV_hub Posted March 6, 2021 Report Posted March 6, 2021 Cut the line down to where you want it and put on your own stainless banjo with a new copper olive and copper washers. I make all my own brake lines definitely no need to go out and buy another set of lines. Quote
locogato11283 Posted March 6, 2021 Report Posted March 6, 2021 Measure out what you want and contact Apex. They are one of the sponsors here.This. Just order them to length. Quote
caleb90 Posted March 7, 2021 Author Report Posted March 7, 2021 think i figured how to make these work. run the right hand side over to the left side, then up steering hoop as a pair.. not ideal for my taste but should be ok. Quote
caleb90 Posted March 7, 2021 Author Report Posted March 7, 2021 but aside that im still trying to figure out how in the hell "loco" managed to get 2 modquad resi clamps to fit on his rear can Quote
caleb90 Posted March 8, 2021 Author Report Posted March 8, 2021 looks the mounting bracket for the heel guard is removed on your frame? Quote
caleb90 Posted March 8, 2021 Author Report Posted March 8, 2021 this is the difference then. all of that stuff is still on mine. not really enough room Quote
Canadianshee Posted March 8, 2021 Report Posted March 8, 2021 this is the difference then. all of that stuff is still on mine. not really enough roomNeeds final adjustment but clamp much cleaner them what they send with shock Sent from my LG-H873 using Tapatalk 1 Quote
Metal_man_Rob Posted March 9, 2021 Report Posted March 9, 2021 Needs final adjustment but clamp much cleaner them what they send with shock Sent from my LG-H873 using TapatalkSo are there benefits to having the remote can as opposed to piggy back? I am looking at suspension now and figured since you’re on the topic and you and Loco both have remotes... I am setting everything up for riding trails in the woods, mostly.Sent from my iPhone using Tapatalk Quote
Canadianshee Posted March 9, 2021 Report Posted March 9, 2021 There are probably many different thoughts on benefits of one or the other. When I replaced my front end Elka gave me a good deal on the rear link and shock as a complete package when ordering front end package. I would more than likely rebuild the OEM rear shock if I did it again. Sent from my LG-H873 using Tapatalk Quote
Metal_man_Rob Posted March 9, 2021 Report Posted March 9, 2021 There are probably many different thoughts on benefits of one or the other. When I replaced my front end Elka gave me a good deal on the rear link and shock as a complete package when ordering front end package. I would more than likely rebuild the OEM rear shock if I did it again. Sent from my LG-H873 using TapatalkThe OEM is pretty decent in the world of banshee suspension options, apparently. The stock swing arm could use help tho. Sent from my iPhone using Tapatalk Quote
Canadianshee Posted March 9, 2021 Report Posted March 9, 2021 The OEM is pretty decent in the world of banshee suspension options, apparently. The stock swing arm could use help tho. Sent from my iPhone using TapatalkStellar or fireball can help you with that. Sent from my LG-H873 using Tapatalk 1 Quote
