Tight_Bolt_Hole Posted October 9, 2020 Author Report Posted October 9, 2020 (edited) 9 minutes ago, Tight_Bolt_Hole said: They are going to let Felons vote now in that state also. The carnies are going to run that state. Meth and Tilt-a-whirl rides for all. *** Skinnard, That smell, playing softly across the entire state. *** Edited October 9, 2020 by Tight_Bolt_Hole Quote
375hp banshees Posted October 9, 2020 Report Posted October 9, 2020 Softly... we crank dat shitSent from my SM-A505U using Tapatalk Quote
375hp banshees Posted October 9, 2020 Report Posted October 9, 2020 Only way to drown out da banjo's Sent from my SM-A505U using Tapatalk Quote
Tight_Bolt_Hole Posted October 9, 2020 Author Report Posted October 9, 2020 6 minutes ago, 375hp banshees said: Only way to drown out da banjo's Sent from my SM-A505U using Tapatalk Someone said Banjo? Now I'm getting nervous. Quote
SKEETER Posted October 9, 2020 Report Posted October 9, 2020 Why you nervous vato? Worried they'll not give you a pig squeal too? Quote
kawa110 Posted October 9, 2020 Report Posted October 9, 2020 Purdy!!!!!!Sent from my iPhone using Tapatalk Quote
n2otoofast4u Posted October 9, 2020 Report Posted October 9, 2020 LOL.....Chino dude doesn’t know Kawa is a turd pusher. Kawa dude didn’t catch the fact that Chino dude is talking about ARs, so he’s a cartel vato who is going to jack Kawa dude for 4 dollars in filters. Florida dude, also a butt dabbler, is ruining entire thing. Quote
Tight_Bolt_Hole Posted October 10, 2020 Author Report Posted October 10, 2020 Just to be clear, I'm white. I'm from the LBC originally. I moved here for the women and cheap beer. Quote
375hp banshees Posted October 10, 2020 Report Posted October 10, 2020 No hair to pull...Will, will be disappointedSent from my SM-A505U using Tapatalk Quote
Tight_Bolt_Hole Posted October 10, 2020 Author Report Posted October 10, 2020 7 hours ago, 375hp banshees said: No hair to pull...Will, will be disappointed Sent from my SM-A505U using Tapatalk I have plenty of back hair. lol Quote
Tight_Bolt_Hole Posted October 11, 2020 Author Report Posted October 11, 2020 (edited) Ok, my dudes I took a closer look today after work. The bike IS setup for two carbs. I have a throttle cable. The bike HAS one(1) Mikuni flat slide on it. So what's the verdict? Do I get another flat slide to match it, or do I buy a new set of something else? What would you do? also, can someone ID this carb for me? Edited October 11, 2020 by Tight_Bolt_Hole Quote
Tight_Bolt_Hole Posted October 11, 2020 Author Report Posted October 11, 2020 Now that I'm google foo on the subject. I'm seeing that the tweeker pecked at the carb that's on it also... So it's missing parts and junk now.... I need a set.... I can see this bike has pipes, a cnc head and I could possibly have wiesco pistons... what carb is best for this setup? Should I buy a set of flat slides for it again? Quote
Tight_Bolt_Hole Posted October 11, 2020 Author Report Posted October 11, 2020 What about this set? https://shop.bansheedepot.com/28mm-Mikuni-Flat-Slide-Carburetor-Kit-22-5727.htm Quote
375hp banshees Posted October 11, 2020 Report Posted October 11, 2020 If you start over i'd go with 28 Keihin pwk, a cable & thumb throttle, longer carb cap threaded inserts & ask around, or look in jetting thread, for jets range to start with. From a reputable builder / shop. Tony is a stand up guy from everything ive heard or F.A.S.T., west coast atv, not sure if driveline sells carbs. just not from ebay,BP or any of rays alias Before you get to far, i'd do a compression test, pull the pipes & look at pistons ( try & see #'s and see what kinda shape they & bore are in) & post up a pick of the cylinders (@ the intake runner where the letters & symbol is) and search leak down on here & test that while pipes are off Sent from my SM-A505U using Tapatalk Quote
Tight_Bolt_Hole Posted October 11, 2020 Author Report Posted October 11, 2020 (edited) 10 hours ago, 375hp banshees said: If you start over i'd go with 28 Keihin pwk, a cable & thumb throttle, longer carb cap threaded inserts & ask around, or look in jetting thread, for jets range to start with. From a reputable builder / shop. Tony is a stand up guy from everything ive heard or F.A.S.T., west coast atv, not sure if driveline sells carbs. just not from ebay,BP or any of rays alias Before you get to far, i'd do a compression test, pull the pipes & look at pistons ( try & see #'s and see what kinda shape they & bore are in) & post up a pick of the cylinders (@ the intake runner where the letters & symbol is) and search leak down on here & test that while pipes are off Sent from my SM-A505U using Tapatalk Ok, Got it. Everyone likes that Keihin PWK in 28mm and a thumb throttle. That kit from WC ATV is around $400. Seems reasonable. For the compression test. Should I do wet or dry? They told me it's been sitting for 6 years. Edited October 11, 2020 by Tight_Bolt_Hole Quote
