Tight_Bolt_Hole
Everything posted by Tight_Bolt_Hole
I need to buy a new set of flat slides for my project. figured I may as well jet them for E85, it's cheap and readily available in my area. I was going to buy a range of idle/main jets. What range should I buy?
So, I picked up a banshee at storage auction. It's missing random bits and pieces. I'm trying to figure out the best thing to do with the exhaust. I have the expansion chamber, mid pipe and silencer/spark arrester(hope that's the correct part names). however, I'm missing the connecting hardware between the three. I found the clamps that go between the Expansion chamber and mid pipe. What goes between the mid pipe and silencer? Someone tried to weld the two pieces together, as shown in the photo below(I knocked all the shit weld off and cleaned it up with a Dremel tool). Can I simply squirt some RTV high temp between the two and use the correct fasteners? Do I need a special gasket? Should I just pony up the dough for the FMF mid pipe and silencer? A little help for a noob is appreciated. Thanks my dudes and dude'ets
FINALLY. I just bought my first Banshee!
Tight_Bolt_Hole replied to Tight_Bolt_Hole's topic in Banshee Repairs and Mods
What do you guys think? I knocked off all the shit weld. leaned up the surface on both sides and pressed the flange flat. I got the correct hardware. Just shoot a bead of High Temp RTV and bolt it up? Edit: Happy Halloween Fags. -
Yea, I don't know what this guy was thinking. High on the pipe most likely. -
Hey, It's all good! Cycled the pistons while looking in the exhaust ports. NO VISUAL DAMAGE! SMOOTH! I didn't have any two stroke, so I did the right thing and sprayed out the cylinder w/ dub 40 first and then dumped some 90-75w gear oil down the shoot. Wet compression test yielded 170+ psi. in both holes. Nice! I need some help with various garbage I found. Start with this, I looks like someone tried to weld up a gap here between the mid pipe and the can. WTF? Here is a pic of the expansion chambers, mid pipe and can. I think all I need is to clean all the shit weld up and buy the proper can for the mid pipe. Please advise! Next Item, I have two black wires(one with a white stripe) that have been cut from the pack here. Final item, where can I find a good set of rear knobby tires? I think a rim and tire combo would be the best. It's street, hard dirt here in baja, unless your partying the beach. -
Don't feel bad, It's 930 and I'm still holding my dick and drinking a cup of coffee. lol -
It's time. I have most of the day today to mess with it. I'll start the visual inspection and get some numbers on it. That way I can see what I'm working with before I drop 4 bills on carbs. -
I'm surprised about this a little. I totally figured, flat slide and twist throttle was going to be the recommendation. I have little 2 stroke experience, but on a classic crotch rocket w/ carbs, flat slides are always preferred because on a four stroke they are way, way more snappy. -
Ok, Got it. Everyone likes that Keihin PWK in 28mm and a thumb throttle. That kit from WC ATV is around $400. Seems reasonable. For the compression test. Should I do wet or dry? They told me it's been sitting for 6 years. -
What about this set? https://shop.bansheedepot.com/28mm-Mikuni-Flat-Slide-Carburetor-Kit-22-5727.htm -
Now that I'm google foo on the subject. I'm seeing that the tweeker pecked at the carb that's on it also... So it's missing parts and junk now.... I need a set.... I can see this bike has pipes, a cnc head and I could possibly have wiesco pistons... what carb is best for this setup? Should I buy a set of flat slides for it again? -
Ok, my dudes I took a closer look today after work. The bike IS setup for two carbs. I have a throttle cable. The bike HAS one(1) Mikuni flat slide on it. So what's the verdict? Do I get another flat slide to match it, or do I buy a new set of something else? What would you do? also, can someone ID this carb for me? -
I have plenty of back hair. lol -
Just to be clear, I'm white. I'm from the LBC originally. I moved here for the women and cheap beer. -
Someone said Banjo? Now I'm getting nervous. -
*** Skinnard, That smell, playing softly across the entire state. *** -
They are going to let Felons vote now in that state also. The carnies are going to run that state. Meth and Tilt-a-whirl rides for all. -
Words to live by. -
No, This is the tight bolthole lube. No Joke, This shit is amazing. Of all the different brands, this is the best one. It's better than the Lucas. I use it for all types of stuff. When I build a new AR platform rifle I use this for the initial build and follow up with Lucas simi-synthetic ATF for CLP. -
Here's a Pre pic for you. The big bottle, Cowboy. -
I might get a discount on them filters too..... lmao! -
I am? jaja -
Party time. I drink Mexican beer, Tecate, I hope that's ok with you my friend. -
I'll come up there or we could meet somewhere in the middle that is fun to ride, Anza Borego or Glamis, whatever. I put the filters and we can toss some sand!
