both pistons were longer and the one that was smoking more then the other was the right side and when i opened it up the head/piston/cylinder was more scared and thats also the side that had the wristpin fall apart also i tried to contact him but it said that he cant recieve messages
3 minutes ago, hoppedupandcutdown said:
Pull the wrist pin out of the one (half way) stick it in the other, to line that up exactly,.Take new pic. I wanna see a broken pin too. (literally never have)
sorry i threw the wrist pins away after it broke but what do u think caused the pistons to look like that
Do you have a way to measure the old cylinders & compare it to current cylinders . assuming the spare cylinders you said you had,  are from the old pistons you are using in comparison... Did he give you an old crank?
