JackPevehouse8 Posted January 30, 2018 Report Posted January 30, 2018 Looking to buy a good used amp link for my banshee Quote
trickedcarbine Posted January 30, 2018 Report Posted January 30, 2018 Junk, they rob power. Find a good tensioner crime someone like Chariot. Quote
kawa110 Posted January 31, 2018 Report Posted January 31, 2018 What’s the scoop on this item??? Quote
sheerider11 Posted January 31, 2018 Report Posted January 31, 2018 What’s the scoop on this item???Don't know. He told me it'll help any shock. I asked about having mine rebuilt and he said it'll still make it better. Can t see how Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
locogato11283 Posted January 31, 2018 Report Posted January 31, 2018 That spacer will make your shock stiffer. Quote
specialblend07 Posted January 31, 2018 Report Posted January 31, 2018 It'll make it stiffer, however it isn't the right way to go about it. Quote
kawa110 Posted January 31, 2018 Report Posted January 31, 2018 ^^thats pretty much what I concluded but I know very little and wasn’t sure...How do I determine spring rates? I have a rear dual spring stock shock, And some axis triple spring fronts(all need rebuilt) that I plan on using. Quote
97Screamer Posted January 31, 2018 Report Posted January 31, 2018 1 hour ago, kawa110 said: Maybe this... That will tell you what rates you have but a very small error in dimensions will change the stiffness quite a bit. Really just a tool to get you in the ballpark of your current stiffness, not an exact number. You need a compression tester to get the exact number. This also doesn't help you determine the rates you need. Racetech calculator will get you close on the rear. I would think Fireball would be able to get you close on the fronts. If you need to change springs on the fronts better bust out the piggy bank. Each spring will cost $60-$120 in my experience so if you have 6 springs you're better off selling the shocks and buying ones setup for you already IMO. Rear shock with one or two springs is a little easier to stomach. Quote
