jack vo Posted November 23, 2017 Report Posted November 23, 2017 he premixed 20:1 and went threw 5 gallons of premium used klotz..... the bike starts fine but is this going to hurt my engine i told him 40:1 i am displeased i dont think he will borrow it again... Quote
Keno Posted November 23, 2017 Report Posted November 23, 2017 Seriously, be happy he even added oil, let alone too much. Lets do some math! So, 20:1 means 20 parts gasoline to 1 part oil, 20+1=21 total parts. 40:1 means 40 parts gasoline to 1 parts oil, 40+1= 41 total parts. Take 1/41 to get 2.44% oil and 1/21 to get 4.76% oil. So 4.76%-2.44%=2.32%. So he added 2.32% too much oil. This effectively leaned your jetting by 2.32% due to the displacement of the fuel by the oil. I very much doubt a 2.32% change in your jetting is going to do anything unless your jetting was very lean to begin with. Edit: "So he added 2.32% too much oil" is incorrect. He added 100% too much oil. It should have said, "The fuel contained 2.32% too much oil" Quote
Ayesully810 Posted November 23, 2017 Report Posted November 23, 2017 I let my little cousin ride my 4 mil and he crashed it into a tree this last summer. Quit cryinSent from my LGMS210 using Tapatalk 2 Quote
registered user Posted November 23, 2017 Report Posted November 23, 2017 u would run home to mom if i said how much oil i mix in Quote
spurdy Posted November 23, 2017 Report Posted November 23, 2017 Seriously, be happy he even added oil, let alone too much. Lets do some math! So, 20:1 means 20 parts gasoline to 1 part oil, 20+1=21 total parts. 40:1 means 40 parts gasoline to 1 parts oil, 40+1= 41 total parts. Take 1/41 to get 2.44% oil and 1/21 to get 4.76% oil. So 4.76%-2.44%=2.32%. So he added 2.32% too much oil. This effectively leaned your jetting by 2.32% due to the displacement of the fuel by the oil. I very much doubt a 2.32% change in your jetting is going to do anything unless your jetting was very lean to begin with.This is completely wrong. He doubled the amount of oil he was told to use. He used 32 oz instead of 16 oz to the same amount of fuel. His Motor will be fine but your math needs some serious help. Lol! Sent from my iPhone using Tapatalk Quote
registered user Posted November 23, 2017 Report Posted November 23, 2017 get out with that nonsense. good math has no place around here 2 Quote
Keno Posted November 24, 2017 Report Posted November 24, 2017 5 hours ago, spurdy said: This is completely wrong. He doubled the amount of oil he was told to use. He used 32 oz instead of 16 oz to the same amount of fuel. His Motor will be fine but your math needs some serious help. Lol! Sent from my iPhone using Tapatalk 32/(640+32)=0.0476 16/(640+16)=0.0244 0.0476-0.0244=0.0232 Maybe I am doing something wrong. Please correct me. Edit: I just realized that my math only works if you ADD the oil to 5 gallons of fuel. ie Final volume equals 5 gallons plus the amount of oil added If you put your oil in the jug first then add fuel to the 5 gallon line ( final volume being 5 gallons (640 oz) including the oil) then you are making a 5% (19:1 or 608 oz fuel to 32oz oil ) and a 2.5% (39:1 or 624 oz fuel to 16 oz oil) solution. Then he would have only added 2.5% too much oil. v/v%=(volume solute/(volume solvent+volume solute))x100% so (oil/(gas+oil))x100% = volume% oil Quote
Columbus350 Posted November 24, 2017 Report Posted November 24, 2017 Too much math Sent from my iPhone using Tapatalk Quote
Ayesully810 Posted November 24, 2017 Report Posted November 24, 2017 (edited) 4+5= 7 common core math common core oil mixing it rick fairening Edited November 24, 2017 by Ayesully810 Quote
sleeper06 Posted November 24, 2017 Report Posted November 24, 2017 Simple your friends mix = no damage to your engine 4 Quote
