jack vo
Everything posted by jack vo
  1. I have everything that goes with it.
  2. Was recently given an rd400 engine by a friend. He junked the motorcycle chassis cuz it was crashed. He doesn't want anything to do with motorcycles anymore. I'm thinking about getting a banshee chassis and putting this engine in it. The engine has been ported polished in the head has been milled. It was modified with v Force reeds and has a modern ignition system. From what he told me it took really well to race gas. Is it worth putting in a Banshee chassis or should I be looking for a different chassis to put it in. Thank you
  3. What head do I need to run leaded 110
  4. I got these 34mm pj keihin https://www.ebay.com/itm/201283841209 Have everything together except the carbs What jets should I put in this bike The main is a 152 Pilot jet might be a 34 I have a decked stock head Dune port Shearer inframe pipes +4 timing plate Vf4s And red power bands I have been reading on the forum about jetting but am still a noob by far any help is greatly appreciated
  5. Thx
  6. Will a stock bore banshee with Decked head Vf4s Shearer pipes Dune port See a huge improvement with 34mm carbs and a timing plate?
  7. Any idea what cc that would be with stock crank?
  8. I was just wanting to know how big of aftermarket jugs i can go without a new crank or case mod or adapter purely out of curiosity also i dont want to just bore out my stock jugs to the max and not be able to rebuild it if need be
  9. How big can you go on a stock case without modifications stock welded crank also
  10. Im looking for a good oil but i want alot of smoke
  11. 915 feet Stock bore Milled head Vf4 Shearer pipe Stock carb Dune port Airbox lid delete
  12. I dont know much about switching to race fuel but some where i heard race fuel is not worth it because of higher compression but why? What is the benefit of 110 vs 120 race gas
  13. Thx 4 info
  14. Alba +2+1 i think works tripple shocks stock rear shock that bottom out with my fat ass 225pds
  15. So i have $2000 might spend more This is what i have so far Airbox lid delete Stock carbs Vf4s Decked head Forged pistons Dune port Welded crank Shearer pipes No timing plate yet _________________________________ Thats what i currently have not the best setup but to get alot more out of this i was wanting to go big with the crank but im told that is 1k in case work alone but i dont want to be cheap ... Can u tell me what i can get out of the right size carbs 4mm crank timing plate and race gas if its worth it.... Or in your general opinion what should i do next with this engine build and what kind of numbers can i expect.
  16. ok long story short i was talking to the engine builder i was told that a bigger piston on a banshee will not give me more hp but a stroked banshee will, his explanation was that a bigger piston will slow the engine down due to rotational mass so is this true
  17. is this a good deal https://www.ebay.com/itm/Banshee-421cc-Big-Bore-Cheetah-Cub-Complete-Built-Motor-Crankcases-Bottom-End-/282765153918?_trksid=p2385738.m4383.l4275.c10 https://www.ebay.com/itm/Banshee-521cc-10-mil-Big-Bore-Super-Cheetah-Cub-Complete-Built-Motor-Crankcases/263375584267?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Dab0916ff64c34a7c8a798933d01c04f1%26pid%3D100677%26rk%3D6%26rkt%3D30%26sd%3D282765153918%26itm%3D263375584267&_trksid=p2385738.c100677.m4598
  18. he premixed 20:1 and went threw 5 gallons of premium used klotz..... the bike starts fine but is this going to hurt my engine i told him 40:1 i am displeased i dont think he will borrow it again...
  19. im needing some opinions on a larger cc engine build something with massive amount of grunt to it im thinking a 6 or 700cc engine any idea what something like this might cost will it sit inside the frame with out modifications
