Banshee SE Posted November 17, 2017 Report Posted November 17, 2017 Is this thing useable or not? What you guys think? Sent from my iPad using Tapatalk Quote
ZillaFreak Posted November 17, 2017 Report Posted November 17, 2017 You can try to lap it, but I wouldn't waste the time personally. 1 Quote
Toybreaker Posted November 17, 2017 Report Posted November 17, 2017 yes, if you know what you are doing that is absolutely repairable/usable. DIY mechanic? don't bother........ you will fuck up the taper and it will not seat properly causing all kinds of electrical mischief. 1 Quote
locogato11283 Posted November 17, 2017 Report Posted November 17, 2017 I’ve run WAY worse than that. Clean it up. Put it on. It’ll be fine. Quote
JUSTWANNARACE Posted November 17, 2017 Report Posted November 17, 2017 Put some Dykum on the inside of the flywheel and crank. Lap in with valve lapping compound until all Dykum is removed. Coat the inside of flywheel with some blue loc-tite to create a thin barrier between the 2 metals to avoid electrolysis and pitting. Install as normal. Should be good to go.. jmo 1 Quote
Ayesully810 Posted November 18, 2017 Report Posted November 18, 2017 run it and find out. Takes 2 mins to put a fly wheel on then remove it. Im with ty ty ive ran worse and they worked fine Quote
Banshee SE Posted November 18, 2017 Author Report Posted November 18, 2017 Personally I wont use it but I would like to sell it but first I wanted to know if it can be used like that. Quote
Banshee SE Posted November 18, 2017 Author Report Posted November 18, 2017 I’ve run WAY worse than that. Clean it up. Put it on. It’ll be fine. Yea right!! You, I doubt it!! Lol Quote
locogato11283 Posted November 18, 2017 Report Posted November 18, 2017 Yea right!! You, I doubt it!! LolI have. Not even kidding. Quote
trickedcarbine Posted November 18, 2017 Report Posted November 18, 2017 Lap it then give it a dab of anti sieze. Quote
spurdy Posted November 19, 2017 Report Posted November 19, 2017 Lap it then give it a dab of anti sieze. ^^^this. I wouldn't use loktight on the taper. That's just me. Well, me and this guy. Sent from my iPhone using Tapatalk Quote
Yeepo Posted November 24, 2017 Report Posted November 24, 2017 Mine looked worse than that one. I lapped it real good and its holding fine. Quote
