locogato11283 Posted March 13, 2017 Report Posted March 13, 2017 I'd get rid of that single carb shit ASAP. Do a WOT plug check and see what color the electrode is.. White/grey = lean Tan = good Brown/black = rich Being way too lean or way too rich can cause overheating. Just need to see where you're at. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 What is complete setup? Maybe things could be wrong. Shitty tuning, shitty setup, shitty dyno operator. Serval on stock strokeSingle 35 Pwk main 210 not sure on pilot v-force 3's Probably Circuit pipes. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 Pod filter? Any timing added? As cast cylinders? What domes?No air box, k&n podYa as cast, maybe just clean up. 25 cc domes, pump gas. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 No just installed last week, came to the dunes and had it put on the dyno to get tuned in. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 "It's jetted"Yes but maybe not well. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 What is your cranking compression? Have you check for any air leaks?No just installed last week, came to the dunes and had it put on the dyno to get tuned in Quote
hoppedupandcutdown Posted March 13, 2017 Report Posted March 13, 2017 Was it dyno'd at Stewarts? He leaned out another guy we know til it melted. Quote
sleeper06 Posted March 13, 2017 Report Posted March 13, 2017 I'll bet your leaking compression,did you pressure test motor? What's your domes and fuel? Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 Was it dyno'd at Stewarts? He leaned out another guy we know til it melted.Yes, Randy did it. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 Should have made sure it was good. Check compression, then leakdown test it. As said, sounds like you might have a pinched o-ring causing some issues. With the amount of pressure that sucker had built up. I did look over the cylinder and heads for water leaks. Never done a leak down so I can learn. Quote
trickedcarbine Posted March 13, 2017 Report Posted March 13, 2017 Single 35 Pwk. 210 main I believe is what he said. Not sure about the pilot. I didn't ask but should have.It was a 2/1 intake on a Serval? To be honest, if there wasn't a bigger bowl on that carb and larger fuel valve, you'd be hard pressed to feed a good set of cylinders like a Serval. I've set up a dozen or so 2/1 intakes and I just can't see that motor being happy on one 35mm. 1 Quote
trickedcarbine Posted March 13, 2017 Report Posted March 13, 2017 With the amount of pressure that sucker had built up. I did look over the cylinder and heads for water leaks. Never done a leak down so I can learn. Post pictures of spark plugs. Close up on the strap, straight view of the bottom, and side/angle type view of the strap as well. A leak down is a way to determine that the motor is indeed sealed up and not sucking in additional air or eating coolant. Use expansion plugs from an auto store on the exhaust, and make two PVC caps to go in the intake boots. One should have a gauge, the other should have a valve stem. Only put 6psi in the motor and it should hold for roughly 6 mins. In all honesty, if a motor has an air leak though, it will lean hang off idle and you'd know there was an issue. I'd bet you are letting compression blow by in to the coolant system. If you kick it a few times and listen, you may be able to hear it gurgling air pressure in to the coolant system. Quote
dalegoldston Posted March 13, 2017 Author Report Posted March 13, 2017 Post pictures of spark plugs. Close up on the strap, straight view of the bottom, and side/angle type view of the strap as well. A leak down is a way to determine that the motor is indeed sealed up and not sucking in additional air or eating coolant. Use expansion plugs from an auto store on the exhaust, and make two PVC caps to go in the intake boots. One should have a gauge, the other should have a valve stem. Only put 6psi in the motor and it should hold for roughly 6 mins. In all honesty, if a motor has an air leak though, it will lean hang off idle and you'd know there was an issue. I'd bet you are letting compression blow by in to the coolant system. If you kick it a few times and listen, you may be able to hear it gurgling air pressure in to the coolant system. My quad had a set of ported cylinders on. Dyno'd at 55, I had no more bores left so I bought a serval. I installed and had it tuned on a dyno. I was at a 180 main I checked and now it has a 155. The set up is in the comments. Quote
