dalegoldston
Everything posted by dalegoldston
  1. Decided not to use these. Never ran. $600 Sent from my SM-G965U using Tapatalk
  2. Looking to trade new 34mm kehien carbs, misc jets,intake, pods and throttle cable. Never ran just decided to not use these. Looking for shocks or dyno port or moto fast 2 to 1 pipe and silencer. Thanks Dale Sent from my SM-G965U using Tapatalk
  3. 28 to 33's Sent from my SM-T580 using Tapatalk
  4. Thanks for the info. I may search for a pair of 28s or 33s. I like the idea of two new carbs. I will see what fast has to offer.
  5. I ride a wide variety of ways. From trails to dunes, probably more trails than dunes though.
  6. I have a 421 serval and run a single 35mm keihin carb. Looking to go to dual carbs. I understand it will run alot better with duals. Suggestion on size and shop to buy from. Thanks for the help.
  7. Looking for a set of carbs. Thanks. Sent from my SM-G965U using Tapatalk
  8. There are no dumb questions, but yes I did.
  9. No its gonna be awhile. Back to work for now. Once I do a leak down and up my main some I will post a update. Thanks for all the comments and suggestions.
  10. Yes I pulled the cover and it spun when moving the kick starter.
  11. That's what I thought. Even if the other cylinders put out more hp. These are bigger so I figured larger jet for sure. I really don't know about the needle.
  12. And he went down on the main that confused me. Guess I will get a set of duals and do a leak down. Probably should not ride now to much risk of doing damage.
  13. My quad had a set of ported cylinders on. Dyno'd at 55, I had no more bores left so I bought a serval. I installed and had it tuned on a dyno. I was at a 180 main I checked and now it has a 155. The set up is in the comments.
  14. With the amount of pressure that sucker had built up. I did look over the cylinder and heads for water leaks. Never done a leak down so I can learn.
  15. No just installed last week, came to the dunes and had it put on the dyno to get tuned in
  16. No just installed last week, came to the dunes and had it put on the dyno to get tuned in.
  17. No air box, k&n podYa as cast, maybe just clean up. 25 cc domes, pump gas.
  18. Serval on stock strokeSingle 35 Pwk main 210 not sure on pilot v-force 3's Probably Circuit pipes.
  19. I was thinking that as well. But have no clue as what could be wrong. Unless it was with the dyno.
  20. Maybe it was the same for the dyno guy. I'll pull the plugs in the morning and look. Does that do any good if not looking at them from a plug chop?
