Dirt, Sand, Asphalt guys.
What you think this MSD set up is worth?
I don't know anything bout this setup so any info will help.
Thanks
2ff52e7d9a7d72099e791f235117cf22.jpg45bab58f3dad1558b970038b61718a9d.jpgcc3f956946db8f0631673b7d3f73447f.jpg
There is definitely weight to be saved on the battery these days. FTZ did a lot with those when they came out. They are mostly doing small sprint car type stuff these days, but it might be worth giving them a call.
  • Like 1
Agreed there. Think someone mentioned that awhile ago when a couple pics were posted in my build thread.
I don't plan on using this setup, just thinking bout selling it.
If it comes down to it, I'll give them a holla.
Thanks
What are your intentions with the bike? Set records, or have fun?
Just a fun adrenaline fix.
Probably won't see any dirt, just some sand and possibly a couple dunes.
OEM route is what I'm wanting to go, as I was told it's a lot less hassle and easy to work with.
I have a setup similar and I think it was $2500 new. Or maybe it was $1500, I don't remember.. But it ain't cheap.
Appreciate the numbers J-Madd.
Are a lot of guys running this kind of set up at the tracks?
I'm just going to be the bad news guy. I hope you didn't pay much for that! What you have is a cobbled up mess. A tab is broke off the box, the power supply looks like a fire hazard, the batteries are old and probably out of spec, there just isn't much there that has value IMO. I would keep it, clean it up, leave the wife/kids home one weekend, and play with it. Probably won't see any magical gain, but you will learn a few things in the process.
  • Like 2
No bad news at all. This came as a package deal with the engine.
Way you describe it, it has be pretty old school then? Got some stuff for a good setup, just not a good layout.
Winters almost here and that means nothing but time. I work at a weld shop so I'll see what they have to clean it up.
Got any suggestions for the power source?
Unfortunately the set up is too expensive for 99% of the banshee community. That's the main reason no one fucks with it from a business standpoint. Builders cater to customer wants and most want cheap, do I think there's a need for a aftermarket ignition system in the asphalt community , he'll yeh. Most guys can't comprehend the effects of timing as you progress down the track . If I never played with street bikes in a drag platform I wouldn't know either but we see major gains with the rite tune, I also have seen an 8sec bike run 10s with the wrong tune
Gotcha, didn't look that close, what about a small lithium battery with battery tender leads so u can plug in wherever, only benefit with the way it is , is having extra charged batteries waiting
