bigweav81 Posted September 2, 2016 Report Posted September 2, 2016 Post a pic of your set up/jigs shit like that. No one claimed it wasn't doable. There isn't a future in it money wise. I'm all for diy shit. Sent from my SM-S820L using Tapatalk Quote
j.m.wright545 Posted September 2, 2016 Report Posted September 2, 2016 Post a pic of your set up/jigs shit like that. No one claimed it wasn't doable. There isn't a future in it money wise. I'm all for diy shit. Sent from my SM-S820L using Tapatalk When I get home I'll pm you a picture of my setup with the truing stand and jig plus you need a compress Sent from my iPhone using Tapatalk Quote
bigweav81 Posted September 3, 2016 Report Posted September 3, 2016 (edited) No pics needed lol. Cool you're learning, and doing your own thing. Stick around, and be humble. When you stumble there's plenty of peeps willing to share....if you're willing to listen. Sent from my SM-S820L using Tapatalk Edited September 3, 2016 by bigweav81 Quote
j.m.wright545 Posted September 3, 2016 Report Posted September 3, 2016 No pics needed lol. Cool you're learning, and doing your own thing. Stick around, and be humble. When you stumble there's plenty of peeps willing to share....if you're willing to listen. Sent from my SM-S820L using Tapatalk I'm always learning and take everything into consideration but i Just dislike when people try to knock my hustle down when I'm still learning Sent from my iPhone using Tapatalk Quote
ClaudeMachining Posted September 3, 2016 Report Posted September 3, 2016 I'm always learning and take everything into consideration but i Just dislike when people try to knock my hustle down when I'm still learning Sent from my iPhone using Tapatalk Dont mind N2, he's a part changer. Quote
sleeper06 Posted September 3, 2016 Report Posted September 3, 2016 Measure top of deck to bottom of port in mm and same way to top of port . Only thing I can tell you on building cranks is standard true stands are no good , you have to block the center bearings and true each side center out. pressing them is the easy part . The hardest part is learning to use your tig to manipulate the web true , you can true something perfect then weld it and be out 3-7 thou , I've goot about 40 or so under my belt now and I'm getting quicker n quicker Quote
j.m.wright545 Posted September 3, 2016 Report Posted September 3, 2016 Measure top of deck to bottom of port in mm and same way to top of port . Only thing I can tell you on building cranks is standard true stands are no good , you have to block the center bearings and true each side center out. pressing them is the easy part . The hardest part is learning to use your tig to manipulate the web true , you can true something perfect then weld it and be out 3-7 thou , I've goot about 40 or so under my belt now and I'm getting quicker n quickerI have v blocks is that good or no Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted September 3, 2016 Report Posted September 3, 2016 Single cranks aren't bad. Twins, triples, and quad cylinders get interesting. I've done a few singles, but I wouldn't touch a multi cyl set up. Quote
registered user Posted September 3, 2016 Report Posted September 3, 2016 you planning to open up shop or just do your own stuff ? to me it doesn't make sense to get involved with cranks for personal projects but that's just me. let someone else like crankworks deal with it and you worry about the head, crankcase and cylinder stuff. Quote
j.m.wright545 Posted September 3, 2016 Report Posted September 3, 2016 you planning to open up shop or just do your own stuff ? to me it doesn't make sense to get involved with cranks for personal projects but that's just me. let someone else like crankworks deal with it and you worry about the head, crankcase and cylinder stuff.You do have a point but i just want the knowledge because I may want to build a drag motor in the long run but I just want to know more and more on how to make them faster and fix them Sent from my iPhone using Tapatalk 1 Quote
registered user Posted September 5, 2016 Report Posted September 5, 2016 put your money in porting tools, a small 3 in 1 mill lathe and a welder. those things will benefit you most Quote
j.m.wright545 Posted September 5, 2016 Report Posted September 5, 2016 put your money in porting tools, a small 3 in 1 mill lathe and a welder. those things will benefit you mostThank you for tips, should I go with ccs supply for porting Sent from my iPhone using Tapatalk Quote
bigweav81 Posted September 5, 2016 Report Posted September 5, 2016 Buy a few books, and do some reading. Bell's book is a great one. Jennings is good as well....all the same old shit just less, and more of certain info vs others. Cc speciality is where it's at tool wise, but be prepared to spend a little money. Buy some junkers, and get to cutting. Sent from my SM-S820L using Tapatalk Quote
j.m.wright545 Posted September 5, 2016 Report Posted September 5, 2016 Buy a few books, and do some reading. Bell's book is a great one. Jennings is good as well....all the same old shit just less, and more of certain info vs others. Cc speciality is where it's at tool wise, but be prepared to spend a little money. Buy some junkers, and get to cutting. Sent from my SM-S820L using Tapatalk I have the Jennings books which I'm reading quite delicately to understand everything but I'll purchase the Bell book also to further my readings Sent from my iPhone using Tapatalk Quote
