Cartersbanshee Posted June 21, 2016 Author Report Posted June 21, 2016 Spark plugs were pretty black. Yeah I have stock exhaust. So should I go 4oz to a gallon and raise my jets back up? Quote
trickedcarbine Posted June 21, 2016 Report Posted June 21, 2016 27.5 pilot Needle in middle clip (fine tune after) 260-270 main About 1 1/2 turns out on air screw. 1 Quote
Cartersbanshee Posted June 21, 2016 Author Report Posted June 21, 2016 Thank you Trickedcarbine, I will try it and report back Quote
Cartersbanshee Posted June 21, 2016 Author Report Posted June 21, 2016 Well I'm stalled for a little bit, somehow the ball on my motion pro throttle cable snapped off where it clips into the thumb. So I've ordered a new cable, 260 mains, and 27.5 pilot jets. 240 was the biggest jet I had on hand. Been discussing oil mix with local people, they say to stick to 8oz to a gallon but, not 1 person on here runs that much. I blew up my motor on 5oz to a gallon last time. Do you guys recommend 4 Oz to a gallon? My choice of oil is Quiksilver. Id like to hear someone's recommendation that actually owns a banshee. Don't want to blow it up again! Quote
sheerider11 Posted June 21, 2016 Report Posted June 21, 2016 Well I'm stalled for a little bit, somehow the ball on my motion pro throttle cable snapped off where it clips into the thumb. So I've ordered a new cable, 260 mains, and 27.5 pilot jets. 240 was the biggest jet I had on hand. Been discussing oil mix with local people, they say to stick to 8oz to a gallon but, not 1 person on here runs that much. I blew up my motor on 5oz to a gallon last time. Do you guys recommend 4 Oz to a gallon? My choice of oil is Quiksilver. Id like to hear someone's recommendation that actually owns a banshee. Don't want to blow it up again!I have no idea what these numbers equal out to.. 40:1 or 32:1 is what most people run. I've never heard of quicksilver oil. Maybe switch over to a better known brand if possible. Belray maxima klotz even yamahalube Quote
sheerider11 Posted June 21, 2016 Report Posted June 21, 2016 So a quick search and quicksilver only makes 2 stroke oil for boats. Never really looked into why, but I've always been told not to use that in anything other then a boat. Quote
Cartersbanshee Posted June 21, 2016 Author Report Posted June 21, 2016 Oh wow....it does say Marine but I didn't think it mattered :-\ Quote
troyzstang Posted June 21, 2016 Report Posted June 21, 2016 Welcome to BansheeHQ Ahhh yeah you need a little help. 32-1 mix ratio = 4 oz per gallon Please find a quality atv 2 stroke oil. Also continue to ask questions and LISTEN to members when they offer sound advice. Once again welcome 1 Quote
trickedcarbine Posted June 21, 2016 Report Posted June 21, 2016 Order the 270 as well. It would suck to pay freight for a tiny piece of brass, ride it once and need just a little more fuel and have to wait to ship another one. Quote
Cartersbanshee Posted June 21, 2016 Author Report Posted June 21, 2016 Thanks Troy for the welcome! What's a good 2 stroke oil I can find at a local store? Need a good oil cause we go on 8 hour rides and don't want to blow up on the trails. I already ordered the 260s so let's hope it works! Will order 270s if they dont. Quote
guns4children Posted June 21, 2016 Report Posted June 21, 2016 I use klotz super template and I'm sure alot of others do also. Rocky Mountain ATV sells it and if you spend $75 or more it ships free. Quote
Cartersbanshee Posted June 22, 2016 Author Report Posted June 22, 2016 Sent from my SAMSUNG-SM-G920A using Tapatalk Quote
Cartersbanshee Posted June 23, 2016 Author Report Posted June 23, 2016 I'm not seeing good results on the klotz, reviews say it gums up and it's also expensive. Is there a cheaper oil with no benol in it that I can find at autozone or walmart? Quote
sheerider11 Posted June 23, 2016 Report Posted June 23, 2016 I'm not seeing good results on the klotz, reviews say it gums up and it's also expensive. Is there a cheaper oil with no benol in it that I can find at autozone or walmart?I don't know where you looked and see people having bad results.But you can try 927, h1r, dominator. Your trying to be cheap on the oil that lubricates your pistons and crank?? Does that really seem like the area you want to be cheap in? 1 Quote
Larry's Shee Posted June 23, 2016 Report Posted June 23, 2016 Boats operate at lower rpm, temps, power output, and more constant speed, different oil needs. As mentioned, being cheap on oil means you should pick a different hobby. Quote
