Deezil Posted May 1, 2016 Report Posted May 1, 2016 Acquired my first banshee yesterday. Pretty stock other than pipes, any must do/low buck stuff I should do to it? Just want a solid reliable machine. Thanks Sent from my iPhone using Tapatalk 1 Quote
Deezil Posted May 1, 2016 Author Report Posted May 1, 2016 By lynden. Any others up here? Looking for uncut front fender too. Sent from my iPad using Tapatalk Quote
trickedcarbine Posted May 1, 2016 Report Posted May 1, 2016 Clean carbs, clean/rebuild petcock, replace choke tube, delete TORS and parking break, new brake pads, grease all pivot points, lube chain, new swing arm pivot bearings, new fluids, fresh plugs, and clean and dialectric grease every plug. 1 Quote
bluebanshee98 Posted May 1, 2016 Report Posted May 1, 2016 Change oil, new plugs, clean carbs, check jetting to make sure it's correct, new 93 gas and premix oil wouldn't hurt. Grease the arms. Chain maintaince- clean, lube, tighten. Clean air filter and lube. If you have a compression tested wouldn't hurt to see where you are in each cylinder and leak down test Quote
Deezil Posted May 1, 2016 Author Report Posted May 1, 2016 They said it was jetted for Idaho. Anyone have a guess on where to start here jet wise? Sent from my iPhone using Tapatalk Quote
bluebanshee98 Posted May 1, 2016 Report Posted May 1, 2016 280 main 27.5 would be a great starting point and pretty close. Whats your elevation? Quote
Big Mike NY Posted May 2, 2016 Report Posted May 2, 2016 Congrats looks clean I like the blue plastics! Quote
Deezil Posted May 2, 2016 Author Report Posted May 2, 2016 280 main 27.5 would be a great starting point and pretty close. Whats your elevation? Low. Lynden is around 120' msl. Quote
Deezil Posted May 2, 2016 Author Report Posted May 2, 2016 (edited) Congrats looks clean I like the blue plastics!Thanks! It's super clean. Look forward to tinkering on it. It does have the tors yet. Woman owned. Edited May 2, 2016 by Deezil Quote
hoppedupandcutdown Posted May 2, 2016 Report Posted May 2, 2016 Better check what jets are in it before you ride much (at all). If it was jetted for St Anthony, you'll be way lean at 120' Quote
Deezil Posted May 2, 2016 Author Report Posted May 2, 2016 Better check what jets are in it before you ride much (at all). If it was jetted for St Anthony, you'll be way lean at 120' That was my thought as well. Thanks Quote
95bansh Posted May 2, 2016 Report Posted May 2, 2016 shaving the head, timing plate, k&n filters, and tors delete Quote
Deezil Posted May 2, 2016 Author Report Posted May 2, 2016 shaving the head, timing plate, k&n filters, and tors delete It has K&N filters, but they are right on the carbs, I did get the stock airbox with it too though, would it be better to put that back on with K&N in that? Ill have to look into the timing plate, I found the tors kits on ebay and amazon, any other recommendation for a location to buy those? Quote
Deezil Posted May 2, 2016 Author Report Posted May 2, 2016 Did a compressions test at lunch, both holes are 120-121psi, it has br8es plugs in it, normal? I put new plugs in and fired it up, took short 1 acre run, will check the plugs later, if its lean it wont smoke much right? (I have not had a 2 stroke in a number of years) Quote
