trickedcarbine Posted January 21, 2016 Report Posted January 21, 2016 I am using VP C-12 & 927 @ 32.1. Now that the weather is in the 20's here i'm having trouble with this mixture clogging up the pilot jets and will not stay running unless the chokes are on. Is it the 927 or the VP? Never had a problem when it was warmer. Thanks.927 will definitely not be a good choice for cold weather. It gel's up in carb jets/orfices & seperates from fuel at freezing temps. For a long while I was in to Amsoil, but after speaking with a lot of guys in to Two Stoke snowmobiles, I have switched to Blendzall with awesome results! Quote
Shee_fast Posted January 21, 2016 Report Posted January 21, 2016 I run amsoil all year round and it gets -10 no prblems ever Sent from my VS810PP using Tapatalk Quote
Craig B Posted January 21, 2016 Author Report Posted January 21, 2016 curious... while on subject... what was the guys opinions on the amsoil? i dont run it anymore personally as I only ran it in my srx's due to the Power valves likely to gum up.... I like the castor based oil better. Klotz and 927. But in this case I will try out the Amsoil and see how it goes. Quote
trickedcarbine Posted January 21, 2016 Report Posted January 21, 2016 I like the castor based oil better. Klotz and 927. But in this case I will try out the Amsoil and see how it goes.Blendzall is a castor. Give their stuff a look. Quote
registered user Posted January 22, 2016 Report Posted January 22, 2016 I would use amsoil for killing weeds behind the house Quote
ClaudeMachining Posted January 22, 2016 Report Posted January 22, 2016 Synto racing ftw! That's what use for about 20 years in everything that have a 2 sfrokes in it. 1 Quote
Craig B Posted January 22, 2016 Author Report Posted January 22, 2016 Blendzall is a castor. Give their stuff a look. I ran that once a long time ago. Hard to get around here. Quote
ClaudeMachining Posted January 22, 2016 Report Posted January 22, 2016 will admit... the 2stroke oil they have is great... ive ran my bike stupid rich and it still burned the fuel clean no fouling plugs.... ive swapped to a different synthetic blend for 1 run and my bike started to spit fuel and foul plugs with no change in temp or elevation... i guess the upside is.. i knew i was overly rich... but the sinto stuff really is impressive. No build up or res.. I bet would of worked perfectly in valve based motors.... it also has additives that pro long fuel life and prevents separation. Yup!! I have no doubt that some other brand of oil works good too, but i always had good results with Sinto. Quote
kawa110 Posted January 22, 2016 Report Posted January 22, 2016 Depends on the bike.....I will only use castor 927 in my 1978 yz250-----yes it will separate and sink to the bottom, if the gas valve is left on the carb bowls will fill with the castor....ensure to turn fuel valve off, shake bike before next ride to mix.......the old motor loves the sticky bean oil! Quote
speeshee Posted January 24, 2016 Report Posted January 24, 2016 I have an open mind on oil. There are a lot of great oils but there are also a couple of shit ones. Sent from my iPhone using Tapatalk Quote
87sheerips Posted January 28, 2016 Report Posted January 28, 2016 Never had an issue with techniplate or benol seperating in the cold. Good stuff. I have good pricing on it here. http://www.jdscustoms.com/product-category/chemicals-and-containers/ Quote
registered user Posted January 29, 2016 Report Posted January 29, 2016 unlikely youll have any problem with supertech. benol is another matter. I don't use it below 45 because the trouble ive had with it. turns cloudy and its down hill from there. clogged pilot jet more than once Quote
Shee_fast Posted February 4, 2016 Report Posted February 4, 2016 Amsoil all the way...anti friction anti scuff and smells great imo Sent from my VS810PP using Tapatalk Quote
registered user Posted February 4, 2016 Report Posted February 4, 2016 last i heard this was anti amsoil site. take your nonsense elsewhere haha Quote
