What's up guys, need some advice. I have a 89 banshee, mods as far as I know are toomey t5s, pwk35s, ported stock cylinders bored 30 over, cool head, chariot intake and reeds, I may be missing something but anyways a few weeks ago it was running like a champ then last week I took it out and it started misfiring bad once it hits the powerband but it would run just fine in the lower to mid rpm range. Now I pulled out my reeds to inspect and they were not fully seated but not bad, I flipped them anyways and now there sealing better. Then I went to take it out but now it won't start, pulled the plugs(replaced last week) and held to the head and kicked over to find little to no spark. Stock coil, ngk wires, electrex cdi, and not sure on the stator. Any help would be appreciated
Sent from my SM-G900V using Tapatalk
  • 3 weeks later...
I would recommend checking the output of the stator too.  its a 100% way to know if the stator is doing its job. do not use a dvom for this. use a test lamp with a bulb not a led. test the lighting and test the ignition wires. the lighting will barely light the lamp when kicking over and the ignition will light up bright. the pick up coil is for spark timing and a scope is the best thing to use to test that. the output of the stator is not a dc voltage and it will be inaccurate with a dvom.
