machinegunbanshee
machinegunbanshee last won the day on August 15 2022
machinegunbanshee had the most liked content!
    White 98 elka stage 3 all the way around. Gay 90s fmf seat cover fmf fatties +2 +1 a arms stock length swingarm shop round house swinger shiny +2 axle for to go more faster. Stock motor with air box lid gone and jetted spot on.
Recent Profile Visitors
1,381 profile views
machinegunbanshee's Achievements
  1. Your right they're not shearer pipes. They have the name engraved on the mounting bracket. I might guess they could be Vito fat bastards? But I have never seen them in person so I could be wrong
  2. Ignition coils rarely fail. But the sometimes do. Definitely check your plug caps too. Hard starting like your referring to can also be a sign of low compression. Do a compression check as well. The hanging idle could be a sign of an air leak somewhere. So I'd recommend doing a leak down test. These are the things I would check if it were me.
  3. Maybe try some plumbers tape and a good, tight cross-thread.
  4. Start with plug caps. Then check coil and plug wires. High idle, check carb sync and idle settings. Could be cause of your problems too. Also it could be an air leak. Do a leak down test too.
  5. I emailed him. I'm on the list. 1.5 years before he expects to have mine done. Op... sorry if I took your thread off course.
  6. Damnit. I'm willing to get on a list and wait, but damn if they don't have a list no more
  7. Where did you get a brand new set of snipers? I thought they quit making them?
  8. I hope this starts taking off! Best of luck to you. So much knowledge on this site. Depending on what becomes of this, I'm definitely interested.
  9. Hmmmmm.... reeds good?
  10. This is awesome. Are you familiar with the sundahl frames and geometry?
  11. Definitely check the easy stuff first. But if that's all good and in spec, start thinking about your shift forks. Burnt, bent, or broken.
  12. Might also be time for a leak down test.
  13. Float height? Not sure what spec is but you mentioned it helped. Really seems like a rich condition as it ran better as the bowls emptied. Keep in mind as you use less oil in the premix you are richening your air/fuel ratio as well. Will it Rev out if you take the pipes off and run it briefly?
