Bennett131 Posted October 29, 2015 Report Posted October 29, 2015 You're forgetting the head gasket problems you gotta replace the head studs as well Sent from my iPhone using Tapatalk Yup it is a must Quote
LaegerEliminator Posted October 29, 2015 Report Posted October 29, 2015 You're forgetting the head gasket problems you gotta replace the head studs as well Sent from my iPhone using Tapatalk Yup it is a mustEh, partial truth to this. 6.0 head bolts and gaskets will fail from an egr cooler failure/leak or from improper box tunes. Egr cooler leaks allow coolant into the intake and the motor attempts to hydro lock, but the oem bolts stretch instead. The early tunes added too much timing causing head lift/gasket failure. Doing studs and gaskets is not a must do given the egr is removed and proper tuning used. The oem gaskets are the best product available to use. Studs will certainly drastically reduce the chances of head lift unless extreme boost is achieved. Quote
Bennett131 Posted October 29, 2015 Report Posted October 29, 2015 Eh, partial truth to this. 6.0 head bolts and gaskets will fail from an egr cooler failure/leak or from improper box tunes. Egr cooler leaks allow coolant into the intake and the motor attempts to hydro lock, but the oem bolts stretch instead. The early tunes added too much timing causing head lift/gasket failure. Doing studs and gaskets is not a must do given the egr is removed and proper tuning used. The oem gaskets are the best product available to use. Studs will certainly drastically reduce the chances of head lift unless extreme boost is achieved. I know the issuies what you said is not false but a brand new truck should not have these issuies from the factory. Quote
LaegerEliminator Posted October 29, 2015 Report Posted October 29, 2015 I know the issuies what you said is not false but a brand new truck should not have these issuies from the factory.Agreed. They should not. There are a rare few that have no issues with numerous miles on them. That being said, Ford and International were the first to try to become emissions compliant with the 6.0. They made mistakes with the emissions designs and unfortunately a lot of consumers had to deal with the issues. All three have experienced emissions equipment issues though. Even the beloved Cummins. Quote
87sheerips Posted October 30, 2015 Author Report Posted October 30, 2015 Do you always drive with your fog lights on during the day? I try to. Thug life. Quote
Gunner18 Posted October 30, 2015 Report Posted October 30, 2015 I try to. Thug life. Haha I'm gonna install my 50 inch led and drive around in the light with it on. Quote
Gunner18 Posted October 30, 2015 Report Posted October 30, 2015 I try to. Thug life.All it needs is some wheels but clean ride man . Quote
87sheerips Posted October 30, 2015 Author Report Posted October 30, 2015 All it needs is some wheels but clean ride man . Thanks man, but the light bar is taking it too far lol Quote
Gunner18 Posted October 30, 2015 Report Posted October 30, 2015 Good amount of miles for an 09. Pretty hard miles I'm sure. Do you travel a lot. Quote
LaegerEliminator Posted October 30, 2015 Report Posted October 30, 2015 09 Cummins I'm assuming that motor was retuned and the egr turned off or removed? Quote
willaduncan Posted October 30, 2015 Report Posted October 30, 2015 Ya. I highly doubt an injector is causing that. Most likely the lift pump getting weak or fuel filter needing changed. I'd change the filter and see if it goes away. You might have been right just changed the oil and fuel filter, fuel filter was BLACK and grimey Sent from my iPhone using Tapatalk Quote
F1HDR Posted October 30, 2015 Report Posted October 30, 2015 You might have been right just changed the oil and fuel filter, fuel filter was BLACK and grimey Sent from my iPhone using Tapatalk Regardless of what anyone says, that fuel filter should be changed when you change oil. That black stuff is what happens to fuel in these modern high pressure common rail systems. The high heat and extreme pressure basically burns some of the fuel just in the rail. BG DFC+ fuel additive will solve that problem in the first tank. It's the ONLY stuff I recommend or use. Sent from my SM-G900V using Tapatalk Quote
F1HDR Posted October 30, 2015 Report Posted October 30, 2015 I sat through a 3 hr class last night that was specifically about modern diesel fuel, chemical makeup of it, API ratings, BTU values and so on. Sent from my SM-G900V using Tapatalk Quote
Gunner18 Posted October 30, 2015 Report Posted October 30, 2015 Wow everyone's got all this sick ass shit and here I am like Ya I have none of any of this shit Quote
