Chariot Performance Posted October 21, 2015 Author Report Posted October 21, 2015 I believe all 8 plates require a modified pressure plate. The teeth on the basket are a little taller then wiseco and the such just as Mattoon baskets are. 1 Quote
possum Posted October 21, 2015 Report Posted October 21, 2015 This is what happens with aluminum back plates under a hard load. Switch to alloy steel plate, and havent had a prob yet. Quote
locogato11283 Posted October 21, 2015 Report Posted October 21, 2015 I've had an aluminum backing plate explode. Steel FTW. Nice basket Jerry! Quote
sheerider11 Posted October 21, 2015 Report Posted October 21, 2015 Possum what bushings were you using? How hard are the bushings that come with this? Are they comparable to the Mattoon bushings? I throw the Hinson ones in the trash Quote
possum Posted October 21, 2015 Report Posted October 21, 2015 Honestly Im not sure. Dont remember, but it came in a suppossed proven drag motor when I got it. Quote
Tedder Posted October 21, 2015 Report Posted October 21, 2015 With regards to aluminum backing plates - Under hard acceleration or when dumping the clutch on launch the pucks are mashed out of shape and widen. The pressure of them pushing out on the plate makes them bulge and eventually break. Speaking on Jerry's (Chariot) behalf, I've always found him to be great to deal with and his products top notch. Quote
n2otoofast4u Posted October 21, 2015 Report Posted October 21, 2015 Honestly Im not sure. Dont remember, but it came in a suppossed proven drag motor when I got it. Oh boy...... I know how this story ends 1 Quote
Strm Trpr Posted October 21, 2015 Report Posted October 21, 2015 What alloy aluminum are these baskets made from? Quote
Chariot Performance Posted October 21, 2015 Author Report Posted October 21, 2015 The bushings are custom made for us to our specs. They are stronger than all but Mattoon as far as durometer. Durometer of Mattoon is barely higher. Tensile strength is greater with ours than any others. This is the most important spec. Quote
sheerider11 Posted October 21, 2015 Report Posted October 21, 2015 The bushings are custom made for us to our specs. They are stronger than all but Mattoon as far as durometer. Durometer of Mattoon is barely higher. Tensile strength is greater with ours than any others. This is the most important spec.As long as there not the marshmallow style Hinson ones I'm fine with that. Quote
Strm Trpr Posted October 22, 2015 Report Posted October 22, 2015 What alloy aluminum are these baskets made from? Tensile strength is greater with ours than any others. This is the most important spec. Since you mentioned Tensile Strength and how it's the important spec. It's also important to point out that at 212*F 6061-T6 has a tensile yield strength of 38,000 psi. 7075-T6 has a tensile yield strength of 65,000 psi and at 212*F. Quote
Chariot Performance Posted October 22, 2015 Author Report Posted October 22, 2015 We are using a 6061 t6511 that has a yield of 44,000 psi. We have made baskets for other high horsepower bikes for past customers using the same stock from the same mill and with this hard anodizing and have been very happy with them. Quote
Strm Trpr Posted October 22, 2015 Report Posted October 22, 2015 We are using a 6061 t6511 that has a yield of 44,000 psi. We have made baskets for other high horsepower bikes for past customers using the same stock from the same mill and with this hard anodizing and have been very happy with them.Excellent!! Is the cost of 7075-T651 the limiting factor in using that alloy instead? Quote
Chariot Performance Posted October 22, 2015 Author Report Posted October 22, 2015 6061 T6511 is not an inferior aluminum for this application. The exact product we use is also an enhanced version of your standard run of the mill 6061 t6511. We use a very deep penetrating true Hard Coat anodizing as well and that is very important. We have made baskets for other applications with this material and it simply lasts. It also good to point out that all the other good clutch baskets, except Mattoon, use 6061 t6511. Some of them use lesser tempers than t6511 but not the good baskets. Cost is more but not so much that it was a deciding factor. These baskets will not fail. If though there are enough people who just can't accept that we may have to use 7075 on the next run. It won't be because of failures but because everyone has a boss. Even I do, it is you, the customer! As always these baskets are guaranteed! I see you are a loyal customer Strm Trpr and thank you! Jerry Quote
locogato11283 Posted October 22, 2015 Report Posted October 22, 2015 Chariot products FTW! Jerry, what would it take to make a basket that accepts 8 plates with no pressure plate modifications? I assume building it is no issue. Would it take a minimum order? Quote
