yfzrider2005 Posted March 27, 2015 Report Posted March 27, 2015 any help would be great, please don't bash me cause I am new at this. banshee rebuilt few years ago had problems with float sticking on left side , got the carb problem fixed, now it pops when it is cold, when its warm it runs good, did a compression check, with cheap ass thing I bought, read 94lbs one side 92 the other. gimmee some input guys. Quote
yfzrider2005 Posted March 27, 2015 Author Report Posted March 27, 2015 it only pops out of the left side Quote
Sandking Posted March 27, 2015 Report Posted March 27, 2015 Buy a better compression tester if 94/92 is correct time for a new top end. Quote
Gumball12 Posted March 27, 2015 Report Posted March 27, 2015 I had a similar problem and it ended up being a leak in choke connecting tube between the two carbs. Put a new tube and the problem disappeared. Quote
Gumball12 Posted March 27, 2015 Report Posted March 27, 2015 I doubt compression is your problem being that the two cylinders are so close and the bike starts. I used a cheap tester on a build and it read about what yours is reading. Used a buddys snap on and got around 130. 1 Quote
trickedcarbine Posted March 27, 2015 Report Posted March 27, 2015 Have you jetted for the cold? Quote
yfzrider2005 Posted March 27, 2015 Author Report Posted March 27, 2015 runnin 330 main jets not sure what pilots 3rd position on needle, procircuit pipes .030 over is all that is done, about 30 degrees here Quote
yfzrider2005 Posted March 27, 2015 Author Report Posted March 27, 2015 It does the same thing if it is 80 degrees or 30 degrees till it gets warm then its fine Quote
yfzrider2005 Posted March 27, 2015 Author Report Posted March 27, 2015 just want to say thanks to all you guys who have replied, it has been help, cause I was just about to pull top end, u all saved me. thank you so much! the compression tester I have is a cheap one from ebay! Quote
special06shee Posted March 28, 2015 Report Posted March 28, 2015 Before ya buy anything, unscrew plug caps and trim wire back about 1/4" or until you get to solid wire. Screw caps back on and try it. Quote
Larry's Shee Posted March 28, 2015 Report Posted March 28, 2015 Add a bit of dielectric grease to this ^^^^ Quote
lil Doobie420 Posted March 28, 2015 Report Posted March 28, 2015 Set the pickup gap by the flywheel. Worth a shot . Quote
yfzrider2005 Posted April 1, 2015 Author Report Posted April 1, 2015 Not sure if this helps, but i cant get it wet or it wont run, has to sit for a day. And what is the pickup gap? Never heard of this. Still stock stator from 1996 when shee was born. Quote
