registered user Posted January 31, 2015 Report Posted January 31, 2015 anybody have direct experience with the +4 wsm forged crank from tdr or the vitos +4 ? not concearned about the case bearings or rods as ill pull it apart and use my own rods and case bearings. just wondering if the webs and center pin on either of these cranks are good. crankworks is saying $1000 for their billet +4 webs so im looking for a cheaper option that would still hold up Quote
BANSHEE HP Posted January 31, 2015 Report Posted January 31, 2015 I'll sell you a new vitos crank that's doesn't need to be taken apart. Add a max load or tz if it's a straight cut gear drag bike. Quote
RadarRacing Posted January 31, 2015 Report Posted January 31, 2015 I dont see why you would take a new crank apart. Vitos and wsm are good, even the wang crank webs are good, but rods are crap. I have a hotrods 4 mil crank with a bent rod if you want one to rebuild yourself or to use the webs. Quote
registered user Posted January 31, 2015 Author Report Posted January 31, 2015 I dont see why you would take a new crank apart. I have a hotrods 4 mil crank with a bent rod thats why im taking a new one apart. got some different rods and bearings that i want to install. last thing i need is a rod letting go and destroying everything. do you know if the center pin on the wsm have a key or some other locating device to keep both webs in phase ? Quote
n2otoofast4u Posted January 31, 2015 Report Posted January 31, 2015 anybody have direct experience with the +4 wsm forged crank from tdr or the vitos +4 ? not concearned about the case bearings or rods as ill pull it apart and use my own rods and case bearings. just wondering if the webs and center pin on either of these cranks are good. crankworks is saying $1000 for their billet +4 webs so im looking for a cheaper option that would still hold upReinventing the fucking wheel.... FFS Quote
sprinklerman Posted February 1, 2015 Report Posted February 1, 2015 Reinventing the fucking wheel.... FFSNo joke . I mean hot rods hold up fine on 130+ hp alky motors, ,, but apparently someone thinks it's not good enough for them. Operator error and/or lack of proper maintenance is responsible for most failures. Quote
registered user Posted February 1, 2015 Author Report Posted February 1, 2015 fuck hotrods. you guys can use that shit if you want but im gonna use better stuff. just in the last 2 weeks i seen 2 hotrods cranks with broke rods. look around here. probly 50 bent, broke, destroyed hotrods. maybe the new gold rods are better than the junk grey taiwan rods. or maybe not. i could care less. never liked hotrods and im not gonna use their products. if you have pertinat info to the original question then post it. otherwise STFU Quote
rockenrail Posted February 1, 2015 Report Posted February 1, 2015 ^^^^ Rods do snap when they are cheap junk. I agree that hotrods are a great 4 mill rod, I have tried several brands and hotrods are the only rods I have not broken. Quote
sprinklerman Posted February 1, 2015 Report Posted February 1, 2015 fuck hotrods. you guys can use that shit if you want but im gonna use better stuff. just in the last 2 weeks i seen 2 hotrods cranks with broke rods. look around here. probly 50 bent, broke, destroyed hotrods. maybe the new gold rods are better than the junk grey taiwan rods. or maybe not. i could care less. never liked hotrods and im not gonna use their products. if you have pertinat info to the original question then post it. otherwise STFU Until you can produce a Banshee based motor in excess of 130-140hp why don't you STFU? Mmmmkay? Quote
sprinklerman Posted February 1, 2015 Report Posted February 1, 2015 Until you can produce a Banshee based motor in excess of 130-140hp why don't you STFU? Mmmmkay?Edit : let's make it 120 hp. Lots of 4mm DMs running 4mm hot rods cranks,,,and holding together fine. Quote
registered user Posted February 1, 2015 Author Report Posted February 1, 2015 what part of 'im not gonna use hotrods stuff' dont you understand ? Quote
sheerider11 Posted February 1, 2015 Report Posted February 1, 2015 what part of 'im not gonna use hotrods stuff' dont you understand ?so what do you use? Since we are clearly using subpar parts that 99% of builders recommend I'd love to know what a master builder of you caliber is using. Quote
sprinklerman Posted February 1, 2015 Report Posted February 1, 2015 what part of 'im not gonna use hotrods stuff' dont you understand ?I understand all of it. I also understand you're an idiot if you think you need anything "stronger " than that on a 4mm build. Typical under educated know it all. There's a very informative writeup on here from TDR you might want to read. Carry on bud. Btw, care to reveal yourself yet? Quote
registered user Posted February 1, 2015 Author Report Posted February 1, 2015 so what do you use? Since we are clearly using subpar parts that 99% of builders recommend I'd love to know what a master builder of you caliber is using. if people werent such douchbags i would be happy to let you know. i ask a simple question and everyone jumps my ass because i dont use the same parts that joe blow builder and all his customers use. i dont give a shit about joe blow builder and his 5000hp engine Quote
trickedcarbine Posted February 1, 2015 Report Posted February 1, 2015 If you're looking to go that route you might as well just get a cheap wang crank. Or a used Weisco or HotRods for dirt cheap. The HotRods stuff for dirtbikes seems to have a very grim past so I get your reluctance to pony up for a HotRods on your first banshee. However, as stated above the banshee cranks from them are holding up to pretty stellar output. Since you plan on changing the weak link and the used hot rods are abundant it would be the cheapest route yet still give you a solid core. As far as the Vito's cranks, you would be nuts to buy their new style to take it apart. The rods on them are quite stout. They do have a neato key set up as well. Really surprised they aren't selling the frigg out of them. Quote
