Crank weld wore off need help
Bipolarbanshee
Something really fishy here. I'm with n2o on this. There is no way the aluminum case ground away all of the weld. It would have to grind a significant amount of steel off the web all the way around. The weld should be at least 1/16" into the web and pin. It's not just piled on the outside. Even if you took a hard disk grinder and ground 1/8" off the web and pin, there still isn't going to be looseness between the web and pin. It's a really tight press fit all the way through.
  • Like 1
