Crank weld wore off need help
Bipolarbanshee
Ive had one time where brad didnt answer the phone. Some people have been having issues with him but everytime i call it seems to me he drops everything. Had one hiccup when i called about tie rods, but he did tell me a length and my extra yfz 450 tierods fit. Im agreeing with the guys about the case rubbing the weld, that wouldnt likely happen. Plus a guy building these motors like him will most likely not forget to little clips as i have a hard enough time trying to get mine off the main bearing in every motor i have touched
I agree. And how hard is it to snap a pic. If you would have called brad and say hey this crank might have spread instead of being an absolutely dick hole he probably would have helped you out. If it spread and broke the clip then it should be in the gear oil. Same with that situation. Call him and he would be willing to work with you I have no doubt. But you being a dick hole ruined your chances with that.
Nope..it's always automatically someone else's fault.
Hey, maybe he DID screw up. But you automatically assume he did something wrong just isn't right. Sometimes junk just happens.
