Something really fishy here. I'm with n2o on this. There is no way the aluminum case ground away all of the weld. It would have to grind a significant amount of steel off the web all the way around. The weld should be at least 1/16" into the web and pin. It's not just piled on the outside. Even if you took a hard disk grinder and ground 1/8" off the web and pin, there still isn't going to be looseness between the web and pin. It's a really tight press fit all the way through.
  • Like 1
