ghott Posted July 16, 2014 Report Posted July 16, 2014 Sand track this past weekend had a gravel/shale return lane and I ended up with a nice leak in one of my smooth buff 18.5" front tires. I found a small pin hole on the top of the tread this evening thanks to some soapy water. I did some searching but couldn't find much info...wondering if its ok to try and patch/plug this - or should I go ahead and get a new tire? Quote
mailman Posted July 16, 2014 Report Posted July 16, 2014 I have had luck putting a patch on the inside. I got the patch from Napa and the vulcanizing glue. Quote
hoppedupandcutdown Posted July 16, 2014 Report Posted July 16, 2014 I plugged a 2ply AMS sand front tire. Did it at the dunes as a last ditch attempt to keep riding for the weekend without buying a pair of tires there. It's held air for 2 years now, very surprised at that. Quote
ghott Posted July 16, 2014 Author Report Posted July 16, 2014 Thanks for the input. Will try and either get a small shop to patch it or just patch it from the inside myself. Quote
trickedcarbine Posted July 17, 2014 Report Posted July 17, 2014 Patch it from the inside^what he said. Quote
ghott Posted July 18, 2014 Author Report Posted July 18, 2014 Patch on the inside seems to have done the trick. Thanks again fellas. Quote
mailman Posted July 18, 2014 Report Posted July 18, 2014 You're welcome Gary. Glad it worked for you. Quote
trickedcarbine Posted July 19, 2014 Report Posted July 19, 2014 ^ rut roh, lalalalallalalalalalalalalala. Quote
Starwriter Posted July 19, 2014 Report Posted July 19, 2014 سلام You're not from around here, are you? Quote
