B.b.p builders Posted July 12, 2014 Author Report Posted July 12, 2014 Also guys where I am it is not hard core drag racing. I wish it was. Lets call it hobbie racing. But that don't mean I don't want to be fast. And definitely doesn't mean I don't want to win at some point. Got a race In 2 weeks. Quote
SOUTHTHIRTY Posted July 12, 2014 Report Posted July 12, 2014 Loco your not fucing around. .... bbp gear low... are u running a 2-5 or 1-5 trans? Im sure u will get them to break loose on the launch,,, its that 1st gear shift im worried about... (bog)....by the way dont ride a bog out... (super lean condition)... double clutch or kill it... your shift window will be very small wuth that RO .....this is just my opinion I only own 421cc cubs....no big motors Quote
B.b.p builders Posted July 12, 2014 Author Report Posted July 12, 2014 It's 1-5 override n stock location. Thanks for the info on the not riding a bog out! Dam I didn't know that So by short shift window, you are saying I would Finnish 400' in 5th? Also, are you saying I should start with a 15/45 and try that? I ordered a 15, and 16 and a 45, 44, 43 Quote
SOUTHTHIRTY Posted July 12, 2014 Report Posted July 12, 2014 1n2-5 overide? So are u launching in 2nd or 1st ? Start with 15/45 ... see how it likes it .. a long bog will make your pugs very hard to read also ... your on the right path buy all dem gears ... $ well spent Quote
possum Posted July 12, 2014 Report Posted July 12, 2014 No, by a short shift window he means with real tall gearing there is a bigger gap in rpm from one gear to the next. Resulting in you having to rev high enough to stay in the power when shifted without bogging. Then weak overrev in combonation with power curve lies the problem. A strong curve and good overrev helps this problem. but to be on the safe side you run shorter gearing to make it easier to stay in power, then go up lil by lil. I dont think 15 45 will get you to 400' it will be close with a big RO. I hope I explained it clearly. Quote
B.b.p builders Posted July 12, 2014 Author Report Posted July 12, 2014 The override was in the bike. I was told it was 1 threw 5 override. N is in the stock location. I know I have been starting in first and shifting to second wide open. I don't know who cut the override. I do know I'm going to get another one tho to have on deck Quote
B.b.p builders Posted July 12, 2014 Author Report Posted July 12, 2014 No, by a short shift window he means with real tall gearing there is a bigger gap in rpm from one gear to the next. Resulting in you having to rev high enough to stay in the power when shifted without bogging. Then weak overrev in combonation with power curve lies the problem. A strong curve and good overrev helps this problem. but to be on the safe side you run shorter gearing to make it easier to stay in power, then go up lil by lil. I dont think 15 45 will get you to 400' it will be close with a big RO. I hope I explained it clearly.Bike is still not dialled in yet, but I have 16/41Traction sucks! Cause I have a set of 22" sand stars!! I'm finishing 400' in the low end of 4th if shift to fith at 400' it will bog, that's how low I am in 4th as in probably just shifted at 350' I'm still doing alot at once here with this and being so new at it, it's hard for me to know for sure but I'm guessing I'm hitting 4th at about 350' The front end almost lifts when shifting from 1 lst to 2nd if I had better tracktion I'm betting it would lift up a wee bit. Quote
m671054 Posted July 13, 2014 Report Posted July 13, 2014 Those sandstars are the 81ro 14pdl? Sounds like your overgeared for what you have right now. Quote
B.b.p builders Posted July 13, 2014 Author Report Posted July 13, 2014 No those are my tires I have on the way. The sand stars are like a 9 paddle I think. Blew the motor in this thing yesturday tho Quote
n2otoofast4u Posted July 13, 2014 Report Posted July 13, 2014 No those are my tires I have on the way. The sand stars are like a 9 paddle I think. Blew the motor in this thing yesturday tho Puked it already? Quote
SOUTHTHIRTY Posted July 13, 2014 Report Posted July 13, 2014 Did u do a leak down test and comp test before u took it out and ran it ? Quote
B.b.p builders Posted July 13, 2014 Author Report Posted July 13, 2014 Yes I did a leak down test multiple times. Yes cotton LEAN!! Live and learn. Oh well I will get a better motor out of the deal. Quote
SOUTHTHIRTY Posted July 13, 2014 Report Posted July 13, 2014 Toss those carbs bro... lectrons no for beginners. ..I love my Mikuni, s 1 Quote
