I'm slapping a pro design cool head on tomorrow. All I have is stock head nuts. Do I need acorn nuts? I hear a lot of ppl have issues with leaks. I was thinking of just using 1211 case sealer on the nut threads?
Just use the o-rings. No sealer. Go slow when dropping the head. If it won't go down, there is an issue. Also, when dropping the head on some times the o-rings on the bottom may drop down. A dab of grease ran over the o ring will keep it stuck in the groove. Once you get the bottom shell about 1/4 inch from seating, shine a light between the head and cyls to make sure the rings didn't drop. Then once the bottom section is on, put the little o rings in on each stud and install the thin upper top piece.
Alright. I have the engine out of the bike which makes it easier. I can tip the engine up so the o-rings stick to the cool head better. So torque specs are the same with a cool head. 20 ft/lbs?
Sent from my HTC One using Tapatalk
Cause I bought one with 20 cc domes, right now I'm currently piped, pod filters, tors removed, vforce 3. And I was just wondering if I can throw mine on already.. Seems like you did.
Sent from my SM-N900T using Tapatalk
