280 main 30 pilot jet, Coolhead, Fmf exhaust, pod filters. I had a hard time getting fuel into the jugs after getting my cylinders bored and wiseco pistons installed. I opened the plugs and dumped fuel down the jugs. Started right away but will only idle if I have the choke out all the way. I know this means it's lean but with a 30 pilot? Air adjust screw is all the way in. Do I need a larger main? Sounds good when the choke is fully out. Even if it's half way it's idling pretty high. The carb slides are fully down and in the correct carb. Choke tube is connected between the carbs
Sent from my HTC One using Tapatalk
