It is a very hard concept. But what i normally do is hold the kicker down a wee little bit so i can get a socket on the single bolt, turn it counterclockwise until bolt falls out, then sometimes a flat head screw driver is needed to relieve some pressure off the splines. Then pull the kick starter outward, and usually if all went well it will plop right off.
Buy some rattle can chrome paint.
Make a half hearted attempt to mask off the part.
Spray kickstarter with chrome paint and let dry.
Take pictures of machine and list for sale locally.
Buy a 300EX
Join a Honda forum till your air pressures get too low and you need to sell the 300EX.........
I heard filling the tires with helium will make it go faster
My tech advice is catching on.
