paisaroni_mario Posted April 26, 2014 Report Posted April 26, 2014 How can I remove this people? with out having to take it off? Or how can I at least make it look better Sent from my SM-N900T using Tapatalk Quote
Larry's Shee Posted April 26, 2014 Report Posted April 26, 2014 if you're afraid to remove kick starter you need a different hobby Quote
special06shee Posted April 26, 2014 Report Posted April 26, 2014 It is a very hard concept. But what i normally do is hold the kicker down a wee little bit so i can get a socket on the single bolt, turn it counterclockwise until bolt falls out, then sometimes a flat head screw driver is needed to relieve some pressure off the splines. Then pull the kick starter outward, and usually if all went well it will plop right off. Quote
87sheerips Posted April 26, 2014 Report Posted April 26, 2014 remove the bolt completely, it will come right off. Then, sand it or bead blast it and clear coat it. Quote
03DMshee Posted April 26, 2014 Report Posted April 26, 2014 Id let it alone and tell people your going for the patina look! 1 Quote
2004LEBanshee Posted April 26, 2014 Report Posted April 26, 2014 After it rattles for enough years it will just fall off. If your lucky you will find it and then you should have no problem throwing some paint on it. Quote
trickedcarbine Posted May 1, 2014 Report Posted May 1, 2014 Don't be a pussy and pull it off. Then wire wheel it. Or wire wheel it on the bike with everything else around it. Quote
WINDYCITYJOHN400 Posted May 1, 2014 Report Posted May 1, 2014 Buy some rattle can chrome paint. Make a half hearted attempt to mask off the part. Spray kickstarter with chrome paint and let dry. Take pictures of machine and list for sale locally. Buy a 300EX Join a Honda forum till your air pressures get too low and you need to sell the 300EX......... Quote
tdod101 Posted May 3, 2014 Report Posted May 3, 2014 I heard filling the tires with helium will make it go faster Quote
WINDYCITYJOHN400 Posted May 3, 2014 Report Posted May 3, 2014 I heard filling the tires with helium will make it go faster My tech advice is catching on. Quote
Deadbeat Posted May 3, 2014 Report Posted May 3, 2014 mask off the aircleaners and paintbomb the whole bike Quote
