ChrisH1989 Posted April 12, 2014 Report Share Posted April 12, 2014 (edited) I'm not as experienced as any of you on working on banshees. I have an on going problem that I can't pin point. A year ago I flew through some water and after that all she wants to do is bogg out. I have changed the reeds, and rebuilt the carbs. I'm starting to think maybe water in the combustion chamber or possibly I just don't know how to adjust the carbs. I have never changed the jets on the carb. Her mods are T5 exhaust, cool heads and vforce 4 reeds. I ride with an open filter box. For some reason now she won't even run for more than 15 seconds at best. But must of the time I'm just kicking away and she'll give me nothing. Any suggestions? Edited April 12, 2014 by ChrisH1989 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 12, 2014 Report Share Posted April 12, 2014 It's electrical. Check your connections. Going through water will not change your jetting. Have you replaced spark plugs? Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 12, 2014 Author Report Share Posted April 12, 2014 I have no replaced the spark plugs, if you don't mind me asking why do you say electrical? I mean I do get it to run, just not for long Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 12, 2014 Author Report Share Posted April 12, 2014 (edited) And I only mention jetting because I have modded things on the bike and was wondering If I should change the jets Edited April 12, 2014 by ChrisH1989 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 12, 2014 Report Share Posted April 12, 2014 Running through water will not affect jetting. If you rebuilt the carbs and the jets are clean then it's not likely your problem, unless you've installed slides wrong or forgot the choke tube. Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 12, 2014 Author Report Share Posted April 12, 2014 Haven't installed the slides wrong or forgot the choke tube, ok ill go over all the electrical and will get back to you Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 12, 2014 Report Share Posted April 12, 2014 How did it run before it took a bath? Have you changed anything while fucking with it? Is the air filter dry of ALL water? Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 12, 2014 Author Report Share Posted April 12, 2014 Ok so I figured out the stator is cooked and the only way I got it to run the little I did was the power of compression... Any suggestion on which stator to replace it with Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted April 12, 2014 Report Share Posted April 12, 2014 Oem only or talk to sheerider1026 Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 12, 2014 Author Report Share Posted April 12, 2014 Know where I can get one not for 400$? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted April 12, 2014 Report Share Posted April 12, 2014 Wanted section here post a wanted ad Quote Link to comment Share on other sites More sharing options...
special06shee Posted April 12, 2014 Report Share Posted April 12, 2014 Know where I can get one not for 400$?yes, ill sell you one for 350 shipped:) Stators pop up here all the time for about 100bucks. Just make sure you get one with the same plug ends as you currently have Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted April 12, 2014 Report Share Posted April 12, 2014 Know where I can get one not for 400$? Contact Even at RaceTech stators. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 12, 2014 Report Share Posted April 12, 2014 OEM or bust! Quote Link to comment Share on other sites More sharing options...
ChrisH1989 Posted April 15, 2014 Author Report Share Posted April 15, 2014 Anyone know the resistance value on the ignition coil? Quote Link to comment Share on other sites More sharing options...
