I'm not as experienced as any of you on working on banshees. I have an on going problem that I can't pin point. A year ago I flew through some water and after that all she wants to do is bogg out. I have changed the reeds, and rebuilt the carbs. I'm starting to think maybe water in the combustion chamber or possibly I just don't know how to adjust the carbs. I have never changed the jets on the carb. Her mods are T5 exhaust, cool heads and vforce 4 reeds. I ride with an open filter box. For some reason now she won't even run for more than 15 seconds at best. But must of the time I'm just kicking away and she'll give me nothing. Any suggestions?
Edited by ChrisH1989
Running through water will not affect jetting. If you rebuilt the carbs and the jets are clean then it's not likely your problem, unless you've installed slides wrong or forgot the choke tube.
Know where I can get one not for 400$?
yes, ill sell you one for 350 shipped:)
Stators pop up here all the time for about 100bucks. Just make sure you get one with the same plug ends as you currently have
Contact Even at RaceTech stators.
