big bore or stroker
banshee1327
Stick a 7mm crank in your stock cylinders with a set of 795 series 65mm pistons With porting and carbs I'll get you mid to high 80's HP with a broader power curve than a stock stroke big bore. Then down the road when you want more power you can stick a cheetah cub cylinder on top of that and be around 100 HP
IF your going to do +7mm crank you might as well do a +10 since you have to trench the cases either way.
im 99% sure that it becomes cost prohibitive to use stock cylinders over a 7mill. If i remember correctly 10 mill stock cylinders needed spacers welded to the deck and taller sleeves installed. he was using a cost effective example. Edited by m671054
+10mm stroker crank work with stock jugs or do you gotta get new sleeves?
x2
Sent from my XT1080 using Tapatalk
