mailman Posted February 23, 2014 Report Posted February 23, 2014 Hey guys, I don't remember having this problem on my other bikes. I have a 100+ hp duner with a desert tank and a billet gas cap. There is no restriction in the cap or in the overflow hose. This is great for fuel flow to the motor but while duning, I get sprayed with gas sloshing out of the overflow hose. I know I can put a check ball type restrictor in the overflow hose to prevent this but I don't want to burn up the motor on long hill shoot runs by restricting air flow into the tank. What have you guys used with success? ps. I did do a few searches but came up short. Quote
03DMshee Posted February 23, 2014 Report Posted February 23, 2014 What type of hose set up do you have now? Where is the hose routed that its hitting you? Quote
bebetekbanshee358 Posted February 23, 2014 Report Posted February 23, 2014 Loop it.. I never have success with those straws they put on cap.. Always lose them Quote
jbooker82 Posted February 23, 2014 Report Posted February 23, 2014 Run a hose clear down the frame so you or your banshee doesn't get covered in fuel/oil. Quote
mailman Posted February 24, 2014 Author Report Posted February 24, 2014 What type of hose set up do you have now? Where is the hose routed that its hitting you? I have a "check-ball" type one way valve for it but I removed it so the fuel could flow better. I am currently running an open hose right off the cap (about 18 inches long) into the bar clamp. The fuel sloshing is really bad. I lost way too much fuel when the tank was full. Does anyone run a "check ball" one way valve with your bigger motors? Will it flow enough for a long hill run? Quote
registered user Posted February 24, 2014 Report Posted February 24, 2014 you dont have any floats with a needle valve ? Quote
ban99 Posted February 24, 2014 Report Posted February 24, 2014 Run a hose clear down the frame so you or your banshee doesn't get covered in fuel/oil. X2 I think this would be the easiest remedy. Quote
