bebetekbanshee358
Everything posted by bebetekbanshee358
  1. That's negative camber my bro.. Positive the top will tilt outward.. No form of Motorsport likes it..lol
  2. Aluminum has a coating that withstands more heat then the aluminum itself.. Takes more heat to break down the coating then melting it...
  3. Loop it.. I never have success with those straws they put on cap.. Always lose them
  4. Lil doobie 420. That bike u talkin about is my home boy .. "el pachy" and its the fastest stock chassis stock un cut plastics knobby tire bike in pr.. and yes us puerto ricans do amazing things .and thay motor was built in p.r.. . Talk is cheap though.. hoe can a simple drag race sti rr up so mich emotion in ya.. and then say its drug money..lmao..
  5. I'm not a big fan of the atf. I run motorcycle oil.. don't run engine oil becsuse engine oil has friction modifiers ..
  6. They are junk. Stick to oem electronics
  7. Drag arms maybe. Caster is good for straight line drags
  8. that sounds like a lot of [pilot jet ..however u have a top end issue.. I swap from a 50 pilot to a 45. and oh big f\difference bike feels way better.. more power everwhere.. and that's a 421... whats r ur specs'
  9. ill take it @fouled421. send me paypal info
  10. if u got to throw a crank at it dude.. just go 4 mill... they sell cyinders here all the time for around 500 bucks sllready ported for 4 mill. ull never go back... i think u should keep it too...i played around stock motor for 2 years.im very heavy at 260lbs and need motor to push/pull me down the dunes.. i went with a 4mill... wishin i went with a 10 mill supercub or somehting of that nature.. u get tired of stock banshees qwick
  11. hq wat it do... im lookinjg for banshee original headlights in good condition.. im also looking fprhe right side "kickerside" heel guard plastic... its the plastic behind your foot so the tire wont swallow yourfoot... lol.. thnx hq.. if u cant catch me here.. text me 347-236-970 8
  12. u talking cuttin and welding and heating.. but u never bent a pipe??? i dunno dude..
  13. lol..ya ni99az is buggin..goodluck with sale
  14. I would f ran it dude... U say its a 4mil cub....that's not a crazy investment..a crazy investment is a 18dm..10grand...then it's time to cr..but good luck dude..wha would u do if it leaks in same spot again....?
  15. I've heard that.AJAX works miracles....even# 2000 wet sand
  16. Yes sir..hence the word. SYNC
  17. Nice build and awesome looking shock too..I hear Matt does great work..good luck with your build I have a 4mil serval wishing I did a 10mil....gl
  18. A good quality chromoly heim is better than a ball joint any Day of the week...
  19. Try flipping. The pedals around
  20. To banshee dude.. U need to fuck this guy up......so it won't happend again...lol..marine what it do.
  21. Had the same problem 2 weeks ago on the right carb...when I cleaned it up the float height some how changed I adjusted them right on the money I believe it's 21 mm....bikes feels great now..no more leaks....check for a half moon shape on the needle ..if so replace it ..
  22. Pull both spark plug wire simultaneously..thatll. Shut the bike off for,sure :cheers:
  23. . Everything this dude said....god gave you two ears and one mouth......LISTEN!!!!!!!!!!
  24. Nice ddu . I use that copper spray on all motors gaskets....two stroke to four stroke to 700 hp smallblocks... I swear by this halomar stuff..coat gasket once let it sit coat it again let it sit....install it after it sat for about 15 minutes...shit works.....
