jayhawkatv Posted December 10, 2013 Report Posted December 10, 2013 Anyone ever dibble dabble in nitro as an additive to their meth to gain a bit? If so how safe is it? On a www.trx250r.org site someone posted a thread on sharing basic info on it. I'm interested in trying it if it wont detonate my motor. Some say you can add 10% safely. Any thoughts on this. Thanks Quote
m671054 Posted December 10, 2013 Report Posted December 10, 2013 You need to be able to deliver lots of fuel consistantly. main problem is you cant feed enough even at low percentages Quote
dozer Posted December 10, 2013 Report Posted December 10, 2013 a bigger motor is gona be way cheaper than a nitro methane education. there is tons of info on the web. you may want to look at some old planet sand threads. Quote
fastkid Posted December 10, 2013 Report Posted December 10, 2013 I started a thread years back over on planetsand. Great info and advice. http://www.planetsand.com/forums/ubbthreads.php/topics/1038433/2stroke_Nitro_101#Post1038433 Quote
joshb Posted December 10, 2013 Report Posted December 10, 2013 I know a guy that's ran it on his stock cylinder out at LS. It was quite an improvement. Just can't get greedy Quote
DUSTY05 Posted December 10, 2013 Report Posted December 10, 2013 Nasty shit..better know what you are doing! You making this topic makes me think you dont..find someone who is knowledgeable about it or your gonna ruin your shit most likely... when i was in the grudge motorcycle racing there was some guys using it on all motor bikes making CRAZY power!! Quote
jayhawkatv Posted December 11, 2013 Author Report Posted December 11, 2013 No I don't know what I'm doing, hence the reason I started this thread. Nor do I know or ever met anyone that ran it. That could be a clue but I like to push my luck. What other additive made can push the envelope a little more beside nitrous? I want all motor no spray. Its a dune bike primarily. Quote
DUSTY05 Posted December 11, 2013 Report Posted December 11, 2013 Go ahead and push your luck with nitro..lmao thought about mixing with my grudge bike but never did because of all the bs involved to run enough of it to get gains..small amounts added wont impress nobody and when u start mixing enough to feel/make a diffrence your probably gonna melt your motor into a wad of aluminum, the shit is no joke and is for very intelligent people with deep pockets! but by all means go get you some nitro and post your gains.... #1 forget about running it if its a dune bike..drag bike MAYBE #2 You gotta flush the fuel system..and it would probably ruin a 2 stroke bottom end bearings if rode for very long (why i said maybe in a drag bike) #3 you need to mix it by weight, very sensitive to tempature changes..you will need a hyrdometer to measure and mix it consistently #4 Pour a lil bit on the ground and whack with a hammer #5 Nitro doesnt mix with gas they seperate..needs to be mixed with alcohol or methanol..your gonna need new carbs #6 FORGET ABOUT RUNNING IT Quote
jayhawkatv Posted December 11, 2013 Author Report Posted December 11, 2013 let me clarify. I have a drag bike that is just for the dunes. As in its still in a stock chassis. ok well I guess that answers my questions about it. ill just get more motor Quote
n2otoofast4u Posted December 11, 2013 Report Posted December 11, 2013 Can be used effectively and safely. More than 1 way to skin a cat. Quote
sleeper06 Posted December 11, 2013 Report Posted December 11, 2013 I found 5% isn't terrible on motor when it's cold out added to meth it will bring heat back into motor?I have only done testing don't take my word as gospel Quote
jayhawkatv Posted December 11, 2013 Author Report Posted December 11, 2013 yea I was only going to use 5-10% just want a little more umph. Quote
Turbo Chassis Posted December 11, 2013 Report Posted December 11, 2013 nothing will happen by pouring it out and wacking it with a hammer.... some people say they have gotten to 40 percent although i never had that luck mixing it 5-10 percent youll notice a gain but will also notice plugs started to be melted and cracking porcelein on the plugs play with some timing, add fuel, buy an extra piston or two and have some fun!!!! you have to purge your fuel system being on alky period so adding a bit of nitro doesnt add an extra hassel, your already having to do it if you run alky... its not easy stuff to get "right" but even not right you can notice a difference.... theres many different ways people have tried this stuff, some work better than others but it can be done...its just a trial and error thing, if you dont mind maybe having to change a piston or two, or maybe having to clean up a dome...then have some fun and play around with it Quote
DUSTY05 Posted December 11, 2013 Report Posted December 11, 2013 pour it on a hard surface and whack it with a hammer..the shit will combust! smart ass Quote
