barahonapr Posted November 22, 2013 Report Posted November 22, 2013 Alright I know there's lots of topics on this but I'm going to go ahead and put what I got and where I'm at. Got a 421 serval no port work done . 35mm pwk 165 mains, 50 pilot, cel needle middle clip and it's starving on fuel. It'll shut off on me if I open it up. I'm at sea level and it's 70 here.if anymore info is needed let me know. Thanks guys Quote
trickedcarbine Posted November 22, 2013 Report Posted November 22, 2013 What else is done to the fuel system? Dual petcock, gutted gas cap, billet bowls, etc? That stock T fitting won't cut it if that's what you have going on. Quote
barahonapr Posted November 22, 2013 Author Report Posted November 22, 2013 (edited) No duel petcok stock t fitting no billet bowls... Edited November 22, 2013 by barahonapr Quote
dozer Posted November 22, 2013 Report Posted November 22, 2013 what do you mean by itll shut off on me? Quote
barahonapr Posted November 22, 2013 Author Report Posted November 22, 2013 It will shut off on me in 4 or 5 open throttle Quote
trickedcarbine Posted November 22, 2013 Report Posted November 22, 2013 No duel petcok stock t fitting no billet bowls...I commented on that in the build thread you made. Before you even ran it. So your a gambling man, huh? You spent a lot of time and money on a gorgeous bike and yet knowing you had a problem, ran it anyway? That thing was running out of fuel man. If it has no loss in compression I'd say you bet the house and won, but don't try again. Fix the fuel delivery. Quote
locogato11283 Posted November 22, 2013 Report Posted November 22, 2013 FFS. Spend a couple thousand bucks on 4mm Serval... Won't spend $90 on a way to get enough fuel to the carbs. Quote
Deadbeat Posted November 22, 2013 Report Posted November 22, 2013 your bikes leaning out to the point of shutting off , your topend must be nicely run in Quote
bluebanshee98 Posted November 22, 2013 Report Posted November 22, 2013 As the others said get a pingel. Don't worry they have ones with reserve also. Plus it's more bling to the bike Quote
barahonapr Posted November 22, 2013 Author Report Posted November 22, 2013 FFS. Spend a couple thousand bucks on 4mm Serval... Won't spend $90 on a way to get enough fuel to the carbs. It's not that I won't spend it. It's that I didn't kknow.and that's why I asked..now I know thanks to u guys and I will get the correct parts Quote
trickedcarbine Posted November 22, 2013 Report Posted November 22, 2013 You knew as soon as you posted a photo of the carbs in the build thread. ( http://bansheehq.com/forums/index.php?showtopic=150051&&page=17 ) It's ok. You were either impatient or lazy. Either way it's fixable. It's just money. Quote
barahonapr Posted November 22, 2013 Author Report Posted November 22, 2013 (edited) I was impatient..I've waited a long time to build it. But again I didn't know I had to have it..thought it was a suggestion. Either way just ordered one. What do u guys think of my jets? Edited November 22, 2013 by barahonapr Quote
rjdgriff Posted November 22, 2013 Report Posted November 22, 2013 I ran a 48 pilot and a 160 main for riding in 50* weather on my old serval Quote
