WINDYCITYJOHN400 Posted August 12, 2013 Report Posted August 12, 2013 I do everyday, from what I gather its for camera alignment on an app you can download. If you use the wifi to link with your phone and watch video for long periods it eats battery. But to link with the wireless remote isn't supposed to be an issue. The camera app works great to verify your camera angles. (My buddy has a hero 3) He uses the phone to check his shot aim and control the camera. But he doesn't use the wifi to watch anything in replay. He watches the footage after our ride. 1 Quote
J.J. Posted August 12, 2013 Report Posted August 12, 2013 Isn't the silver a go pro 2 and the white a go pro 1? No, what's closer to the truth is that the Hero3 White shares the same 5MP sensor as the HeroHD and the Hero3 Silver shares the same 11MP sensor as the Hero2. All three Hero3 models are smaller then the earlier Hero models and come with WiFi built in as standard. The Hero3 models also use micro SD cards. Quote
LaegerEliminator Posted August 12, 2013 Author Report Posted August 12, 2013 Huh? I use the Wifi for my remote. I strap the remote to my bar clamp and run everything from there. It's perfect when in the dunes. I never have to touch my helmet. Thanks for all of the feed back! So with the remote can you see and confirm visually on the remote if you are recording? With the WiFi and the phone app you can see on your phone what the camera is seeing? Sent from my DROID RAZR using Tapatalk 2 Quote
WINDYCITYJOHN400 Posted August 12, 2013 Report Posted August 12, 2013 Thanks for all of the feed back! So with the remote can you see and confirm visually on the remote if you are recording? With the WiFi and the phone app you can see on your phone what the camera is seeing? Sent from my DROID RAZR using Tapatalk 2 Yep. Quote
LaegerEliminator Posted August 12, 2013 Author Report Posted August 12, 2013 Windy that might be your shortest reply EVER!!! That's pretty cool, those features certainly have to greatly reduce all of the little mishaps with using my original. Nothing worse than thinking you just filmed an awsome ride only to find you didn't... or your angle sucked..... Sent from my DROID RAZR using Tapatalk 2 Quote
J.J. Posted August 12, 2013 Report Posted August 12, 2013 Nothing worse than thinking you just filmed an awsome ride only to find you didn't... or your angle sucked..... Sent from my DROID RAZR using Tapatalk 2 Been there.. Use the phone to set-up the field of view (and/or control the camera if you like) and the wifi remote to control the camera on the fly. Edit: stay away from the Scandisc Ultra Cards http://www.goprofanatics.com/gopro-hd-hero3/3374-unless-you-want-problems-dont-use-32gb-sandisk-ultra-chips.html http://www.goprofanatics.com/gopro-hd-hero3/4009-gopro-no-longer-recommends-sandisk-ultra.html Quote
Glenyboy Posted August 12, 2013 Report Posted August 12, 2013 Here's a run through different scenarios of gp black3 and the Sony, it holds its own for a cheaper camera Quote
Glenyboy Posted August 25, 2013 Report Posted August 25, 2013 Here's a couple of other videos, they were used for the Isle of Man tt http://youtu.be/dLq2Ea-Z-lg The Sony page has some other good videos, here's a mountain bike one... Quote
Uf21 Posted March 16, 2014 Report Posted March 16, 2014 Here's a run through different scenarios of gp black3 and the Sony, it holds its own for a cheaper camera Though the sony is not going to fit under the sun visor of the helmet. Quote
Uf21 Posted March 16, 2014 Report Posted March 16, 2014 Also hows is the white compared to the silver? One is 5mp adn the other is 11mp Quote
Glenyboy Posted March 16, 2014 Report Posted March 16, 2014 Though the sony is not going to fit under the sun visor of the helmet. How do to mean under? There's not a lot of difference in size. Quote
Uf21 Posted March 16, 2014 Report Posted March 16, 2014 How do to mean under? There's not a lot of difference in size. Literally under the visor. The Sony is longer while the gopro is wider. Just won't work. Quote
Glenyboy Posted March 16, 2014 Report Posted March 16, 2014 Never seen anyone mount underneath, normally on top. Like a teletubby! Lol I like the side mount, easier to control the camera. Quote
Glenyboy Posted March 16, 2014 Report Posted March 16, 2014 Well they are around the same height, so if you wanted to construct a mount like that you could. Quote
