I know boring has very little to no gains... HOWEVER. When I spoke to redline in regards to building a 4mil stock cyl set up for the type of riding I did. He recommended going straight to a 66mm bore on Virgin cyls. I had...
I didn't ask why but I'd assuming there is a reason behind it...
my guess would that its the 573mo6600 piston that could be used with a 1mm higher pin height then the 795mo65xx.
That means if you don't have the money to spend 2 grand on a new motor kit, a bore job, port and polish and some Vf reeds will make a big difference
Please..... Stop. Reccomending that people bore their stock cyls is a waste of cylinder life. Never bore a good set of cylinders unless needed. It's not economical at all. If you port cylinders early on in their life, what good does it do to bore it out 2 mm just to chase a few CC's and a handful of ponies. Then the first time the motor needs a rebuild it's time for new cylinders.
Not worth it. Just the fact that you refer to it as "port and polish" indicates you don't quite grasp the concept. These aren't V8 cylinder heads.
  • 2 weeks later...
I have seen combustion chambers, piston domes, and exhaust ports polished. Never have I seen transfers or intakes polished. Not even on the internet.
Better heat transfer, less buildup / deposits, flow, and compression stays where it should be at, but it only helps so much. Try it for yourself.
Omg that jagesage dude Is a retard. Dude learn what the fuck your talking about before you try and give wrong information and argue.
So a special 116 rod would be used? Then even less stress is on the crank?
He refered to the blaster style piston with an additional mm of pin height then the 795 style piston. 795 piston uses 115 rods so an additional mm would be?
i know exactly what you mean but ...
I don't even know
