guys i just sold my can am Ds450
so im in the market for a new Atv,i want to try out the banshee
but a lot of ppl do not recommend it as its not very reliable and require more frequent maintenance than 4 strokes
i love the banshee for its performance
i was looking for an '11 model year but found an 06 model
with the following mods:
new engine, wiseco piston , crank, clutch, in-line cooler, intake, wheel spacers, T5 Complete system, all fluid changed, rear sprocket
asking price is 3300$
the 2011 is 5700$
Not sure where ur from buy in the U.S the last year made was an 06 and 3300 is about the price clean with mods there going for here in SoCal. I love my banshee nothing compares to the performance and I have very lil maintenance to do change the oil keep fluids full had the same motor for two seasons and runs strong my motor is a 409 4 mil crank carbs extended swinger. Save ur self the time buy one and u will never look back
Sent using Tapatalk
i'm from Kuwait
i know the banshee was banned in the US due to emissions
but the last model year was a 2011
we ride mostly open desert and little a bit of street racing
Check to see if it is a new engine or just a rebuild, if they did the work ask them what size piston they used this will indicate wether it's new, and will let you know how much life you have in the cylinders.
I'd go for the older model if the above checks out, as it's nearly half the money and has an exhaust system on it. There's no difference between the two apart from different coloured plastics.
The Ds was very relaible and fast too, racing any 450 bike the DS was always ahead
had complete exhaust, intake, power commander and 15T front Sprocket, the bike was a blast
but compared to banshees and the Raptors , the Ds lacked the power to compete
Banshees are just as reliable as other makes/models of atv's. There is one exception to this......and that is.....it is WAY cheaper to rebuild a banshee motor than any 4 stroke atv motor of there.
There are a few things that you have to watch for when you have ANY 2 stroke.....
Carb jetting and mods.... Both interact with each other........if you lean it out it's going to damage the cylinders.....if you mod the motor and don't change the jottings then it's going to be lean and damage the cylinders.
But jetting is simple and with the knowledge that is one this website it is very easy to get near/where your jetting needs to be.
  • 1 year later...
I know its been a long time
But i got banshee :)
With the following mods
Athena built engine
Stock carbs
Stock crank
Cpi pipes
Timer plate
290 jets
V force 3
I want it to go faster what would u recommend
I was thinking of getting 39mm carbs
Define "Athena built"? Just a cylinder? Is it ported? If so what kind of porting? What size bore and stroke? What head are you running? What gas? I wouldn't go to 39s. Lil big. Maybe 33-35 depending on motor size and how you ride the thing. Do some looking around on here and see what other setups are running. Might try switching to shearer or maybe even sniper pipes from the cpis. Lil more top end.
There might be some gain by switching pipes but probably not the best bang for the buck. Bigger carbs will add some top end power but stock carbs can handle your motor from the sound of it. Like Dave said, what is athena built? Whats your bore and stroke?
*Edit I see you said stock crank. Maybe do a stroker crank and send the cylinders for porting to match the new stroke. What head and dome size?
Thats some hard questions to answer
As im new to the banshee world
And the bike was bought with its current mods
All i know is the
Cylinders are ported
Head is custom
We mostly ride open desert
Bore and stroke i dont know
The bike is 450cc
I just want to beat those raptor 700 with cam piston and bolt ons
