so went for a rip yesterday when my bike came to a loud stop. looked under the motor and seen the crank had destroyed my upper and lower bottom end cases. after taking the motor apart i seen there was alot of damage, the rod let go right under the wristpin and destroyed everything in its path. its a 4mil crank with a 421 drag ported head all bought from kevin. the bike only has about 3-4 tanks of fuel through it and im confused about what could make the rod let go like that. im going to upload some pics so i can get some input from you guys (cylinder repairable?, cause of failure, rebuild suggestions, ect.) my mods are below. im new to uploading so hopefully they work lol
  • Replies 157
  • Created
  • Last Reply
Top Posters In This Topic
Holy shitballs... My guess would be a seizure on that side, but could have been a casting flaw on the rod... What brand crank was it? I know you said it was from Kevin, but I didn't see a brand. If you say your plugs were a chocolate brown, that would indicate that you were not running lean.
Thats fuckin awesome!!!! Worst ive ever seen. I cant really tell cuz my eyes are goin but is that molten alluminum on the right side in the bottom of the case??
You Might as well take the trans and other parts out of those cases and start from scratch. That cylinder might be salvaged but those cases and crank are junk. Thats the worst rod slingin ive seen yet!!!!!
that's what always happens with them cheapo taiwan rods. i would talk to kevin. when i bought my crank from him, he told me he would replace whatever got damaged from the crank breaking, as he was that confident in the crank he sold me. i would call kevin. he seems like a pretty straight shooter.
its my beleif that the taiwan rods can't take the extra mass of the 68mm pistons and at higher rpm the rod stretches too much for the taiwan steel and snap.
Edited by mopar1rules
All to save a few $. "Should of got a wiseco"
I would be furious. How many hours on the motor?
Edited by zach45
i had 5 of those cranks with 29 l/r on the rod either break or bent in a two month period
NONE of them had more than 5passes on them
all came from the same place
Edited by stroking
