stroking
Everything posted by stroking
  1. Hinson spring loaded basket 8plate complete with straight cut.everything still in excellent shape. 843-499-1012 text if you want it $375
  2. Check out the 300ft and hill racing channel on Zello http://zello.me/k/d4ugm
  3. Check out the banshee street kings channel on Zello http://zello.me/k/bJ1rS
  4. Almost new...gas carbs $300 shipped text 843-3030271
  5. $375 shipped...has roller bearing in center text me 843-303-0271
  6. another miss leading info is that alot of compression slows you down....{WRONG)....I SEEN enignes with 225psi run 116-120mph...(on alky).7/10milcubs... you just have to know what to set other things at.... when i port a cub i change the port timimg on the exhaust,but some (builders) just clean up the portand leave the timimg the same they tell you they drag ported it and charge you $450-500 had one tell me he never uses a degree wheel because they dont give accurate readings
  7. dont waste your money if its a cub,builders will just feed you alot of bs,and in the end you will end up with a clean up port job anyway lighter frame,pipes,domes,timing,and gearing will gave way more than leeting someone grind on your cylinder....theres storys i could tell you about BIG TIME engine builders whos ported cylinder and gave me domes to go with them and bikes was no faster than what i could do myself.
  8. is there a difference between renegade alky and vp m1 ? tried m5 but seems to lean the motor down to much,i want to switch to one of the above ones
  9. i have smooth out forks like that and re install them with zero problems....now when you bend a fork then you have a real problem
  10. we'll keep...mods you can take down post not going to gave away a good motor
  11. $3200 with out stator and flywheel and one set of pipes 843-303-0271
  12. $3580 shipped best its going to get and please dont waste time texting me about pictures or questions that has been answered here,if you dont really want to buy. bottom line its a good motor with new crank,domes,piston,pipes,clutches and cases are welded NO epoxy.
  13. Fresh crank/clutch and domes.....comes with two sets of shearers pipes one BRANDNEW black the other is chrome its ready to run. $3950 shipped for motor and pipes don't know about porting,think its just a clean up text ONLY IF serious 843-303-0271 brand new crank just installed
  14. TEXT IF YOU WANT TO BUY ...(ONLY) Its a bearing support cover in good shape...everything needed to install i have .! 843-303-0271 $155 shipped
