350 screamer Posted December 19, 2011 Report Posted December 19, 2011 well i started cleaning up the motor gettin ready for a tear down, check on all the insides looked down through the imports and it appears theres a liquid that the cranks rotating in, its not oil becuase its to thin, wtf!!! is the prob i love my banshee and i want her to runn 100% i have a feeling its dumping to much gas? or it could be just shit from when i was just cleaning it but it does smell like gas and no i wasnt using gas to clean it, wat could be going on with her? thanks in advance Quote
coryv4 Posted December 19, 2011 Report Posted December 19, 2011 It might be the the Two Stroke Enhancement Device allowing too much liquid into your crankcase causing mass amounts of anti 4stroke matter build up. I would seriously make sure your T.S.E.D is adjusted properly. Quote
Zwiser Posted December 20, 2011 Report Posted December 20, 2011 (hint) thats your oil that you mixed into the gas when you last ran it Quote
Jereme6655 Posted December 20, 2011 Report Posted December 20, 2011 man o man....ive never even knew we had imports on these bikes! ill have to check mine soon! all seriousness though....you looked through your intakes....we got that.....could be a few thigns. could be fuel (from floats being jammed and its filled your pipes and backed up into your crankcase)....or some of the motors like to pool oil/gas mix that was either waste or just slop down by the crank.....or your running atf in your tranny and somehow it made its way inside the crankcase....only way to know for sure is to rip it apart and inspect! Quote
HIDEF Posted December 20, 2011 Report Posted December 20, 2011 '' Two Stroke Enhancement Device allowing too much liquid into your crankcase causing mass amounts of anti 4stroke matter build up''. ^^ LMAO ^^ Quote
