HIDEF
Everything posted by HIDEF
  1. ^^^ +2 on what jereme said.. On my shee i put a little dielectric grease in the open connectors on the harness and then electrical taped them closed, and to the harness. But i just wanted to make the harness look neat, and is most likely unnecessary. Good Luck !
  2. I'm no expert by any means, My .02 is to go with the Wiseco. That's what i use and i think that most of the ppl here use them in there banshee's. Good Luck !
  3. just a quick question about this t-stat. would this benefit the engine in the summer time too by holding the hot coolant in the radiator and cooling it off Or would this be something that should be removed in the summer. Thank You Sorry for HiJacking Your thread.
  4. did you come across the Ohm meter-How To about halfway down the page in the link that Andrew gave you. if not its got some decent info on how the meter works.
  5. I had an issue similar to yours with my Dirt Bike. It would not idle at all or would idle to high. I found that the carb was a little dirty from sitting for a while and the slide was sticking a little at the bottom.cleaning it solved my problem but it was a bike with one carb so might not be your issue. Just something for you to try if you didn't already do that first. Good Luck .
  6. My .02 is to leave them off unless there is a clearance issue of some sort.
  7. I Hope Everyone Got Some Good Shee Parts Under The Tree This Year. Have A Great Holiday Everybody .
  8. have you taken a look around the jetting & exhaust forum to compare your jetting to one of the other members bikes with similar mods ,temp, elevation, etc.. IMO if you got good compression and spark then i would start looking into fuel and jetting. Good Luck !!
  9. '' Two Stroke Enhancement Device allowing too much liquid into your crankcase causing mass amounts of anti 4stroke matter build up''. ^^ LMAO ^^
  10. I think if you file them, you would have more room for the plates to slam the fingers and the wear will accelerate, but i may be wrong. i cant tell how bad it looks by the pic but in my opinion i would just replace it if the grooves are really bad.
  11. x3 on the top end rebuild but it wont hurt to do a compression test and post your result just in case.
  12. its a pretty straight forward job nothing to major involved that i remember. only special tool i can think of that you may need is a digital caliper or some type of measuring tool to check your specs. but you may get lucky and see something obvious going on in there and not need it. If i have forgotten anything that you may need to do the job i'm sure somebody will add there opinion before you do the job tomorrow . Good Luck with it .
  13. lol i guess my copy and paste tactics didnt work properly but the part number is # 5N7
  14. i dont know if you already grabbed what you needed from one of the members but if not i dug up some info on this site from a member named ( carvedart ) . im also not sure if your talking about the stock carbs so if you are heres some info The stock carb is: Mikuni VM26SS Spigot (round-slide)<br style="color: rgb(204, 204, 204); font-family: verdana, arial, tahoma, sans-serif; font-size: 11px; line-height: 16px; background-color: rgb(33, 33, 33); ">The stock Jet Needle is: 5N7<br style="color: rgb(204, 204, 204); font-family: verdana, arial, tahoma, sans-serif; font-size: 11px; line-height: 16px; background-color: rgb(33, 33, 33); "><br style="color: rgb(204, 204, 204); font-family: verdana, arial, tahoma, sans-serif; font-size: 11px; line-height: 16px; background-color: rgb(33, 33, 33); ">1st character = needle length (5 = 5 Series, 50.00-59.99mm) 2nd character = amount of taper in 15 min intervals (N = 3 degs 30 mins) 3rd character = materials and finish (7 = [exact length, major OD, point of beginning of taper in reference to clip position, manufacture specific])
  15. wear limit for the friction plates are 2.7 mm (0.106 in ) and the clutch plate warp limit is 0.05 mm (0.002 in ) then the clutch spring ( minimum ) free length is 34.4 mm (1.35 in ) If you need any other specific information from the book let me know.
  16. You kinda have to peel back a layer at a time Like you said. As far as what usually wears. i have noticed a lot of people replacing the clutch basket with one of the billet ones and also the pancake bearing. im not sure if there is any particular defects with the stock ones or not and im sure there is other items to give extra attention as far as the clutch goes that i have forgotten about. im sure some of the experts will chime in on the subject if needed. Good Luck.
  17. Is your adjustment at your clutch lever all the way out ? And check the pointer where the clutch cable attaches to the actuator it should point at the mark on the case. if it does not line up you can adjust it pretty easily and i would also make sure that all your steel and fiber plates are within spec if you have to take off the case cover.i dont know if you have read thru the ( Banshee Bottom End Assembly Walkthrough ) but im pretty sure that it shows you how to adjust and install clutch if thats the route you have to go.
  18. Excellent ! I'm Glad to hear you got it all figured out without to much headache.
  19. did the bike run good before you did the tors elimination and rebuild ? or were you having issues with it before the work was done ?
  20. I'm sorry didn't realize you started another thread for the same question.Good Luck.
  21. have you checked to make sure theres no rust on the metal tabs on the flywheel for the pick up coil. also check the pick up coil gap it should be 0.015"-0.20" or about the thickness of a matchbook cover.also make sure theres no rust between the ing coil and where it mounts to the frame. i dont know if you have read the ( Banshee Electrical FAQ ) yet but it helped me out tremendously.
  22. Let us know how you make out with it.Good luck / If you still dont get it going im sure somebody here will give you some ideas.
  23. Thank you for the reply. Looks like i'm starting winter tear down a little early this year..
  24. i dont believe that anything could be damaged using to much pre mix oil besides fowling plugs but if you dont put enough you will have huge problems. what color was the smoke and did you look at the condition of the transmission oil and coolant to make sure you dont have gasket or o ring leaking.
  25. when i did a search on this site about ratios and types of oils i found alot of people mixing 32:1 BUT some do run 20:1 and some 40:1. i personally run 32:1 without much smoke. any more oil than that it starts fouling my plugs but i do a lot of trail riding. if you type (premix ratio) in the search box there is a post named Official 2 stroke oil mix preference that may help you
