ive always only used just a small flat head screw driver to install them, start both ends then work the rest in with the screw driver.
I was more talking about getting them to seal against the base gasket.
Give kevin at HJR a call and order up two new rubber seals and put them in. I've never had a set of cylinders that leaked, but I'm pretty confident that if yours are leaking, it could be fixed with some new seals. Kevin can hook you up.
- Jared
