So just put a new serval in and it's only running on 1 cylinder. I have spark and fuel. Compression is good. Stock carbs t5 exaust v3 reeds noss cool head adjustable time plate (+4). Any ideas?
choke tube in place? to low of idle? to small pilot pilot airscrew to far out try another set of spark plugs ive had plugs not work from the store dont no why but it happens
also put that timing plate at +3 servals dont like alot of timing are your reeds crack?
If all the basic stuff checks out (choke tube, fuel supply, spark, compression check, etc) then start swapping parts side to side 1 at a time and see if the problem jumps to the other cylinder. Did you do a leak-down test?
Ok so I swapped plug wires no change the carbs should be fine I have 27.5 pilots I think. I I have tors removed but there is still a black box for it and when I plugged it in, it seemed that it was running on both cylinders but then it wouldn't idle anymore. As far as timing goes will going from +4 to +3 make a difference on one cylinder firing? Idk lol.
Piston in backwards? Washer not on mainjet in carb? Forget to put mainjet in carb? Fuel line kinked or clogged? Fuel runs out of line and carbs fine? Float level messed up, no fuelcomin thru carb?
Carbs are in sync. Main jets are there washers are there. Fuel lines are good, good gas flow into carbs. something in carb not working right???? I'm not a carb wiz, but the slides are synced and moving like they should all jets are in place.
wow.....where you been firebanshee? haha long time since i've seen you here....
id agree with fire.....check your carb slides (cut out shape facing the rear of the bike is correct) and are you SURE that your pistons made it in correctly? which way did you point the little arrow on the piston tops?
