Hey guys, What do most of you guys run for spark pkugs?? I did run NGK B8ES on my old motor. which was 130 PSI, Now i just built a 421 with 190 PSI. Im thinking the ones i have just arent cutting the mustard. Do any of your guys run like iridium's or anything??? .
Edited by EvilBanshee
I have heard bad things about getting creative with plug configurations. I run, and always will run NGK BR8ES. Iridiums I've heard have issues with losing electrodes. I may be totally wrong, but someone else will probably chime in with their own personal experiences.
NGK BR8ES for me.
Do you run alky or gas?
I use Race Gas. My old race sled use to run like shit on regular Br8es's, but then i found a Iridium for it and it never fouled again, it ran way better. Im just curious if theirs a nice race plug out their for banshee's.
Most sleds use a 9 heat range plug.. The SRX sleds came with the High Dollar plugs.
NGK BP8ES here.
SP
:headbang: Yep projected tip spark plug. That way it hangs down in the combustion chamber a little farther instead of being recessed in the dome. Then I just side cap the ground strap.
Pic's of each will load off to the side.
Projected tip. (BPR8ES)
http://www.sparkplugs.com/results_cross.asp?pid=bpr8es
Standard tip (BR8ES)
http://www.sparkplugs.com/results_cross.asp?pid=br8es&x=34&y=19
What do you mean by "side cap the ground strap"?
your supposed to run the BR8ES with the stock coil because of the resistor.
realy? I did not know that. mine came brand new with the non resister plugs, and I took it out of the crate and put it together. and the manual shows either one for replacement
Edited by toytech
